![]() | Home > General > check coolant level / low coolant level |
You might need to change the whole coolant expansion tank, especially if your vehicle is within this VIN- range : AA215621-AA224000 and 'Check Coolant Level' warning message is being displayed in the instrument cluster message center despite no leaks being evident and the coolant is at the correct level.
iz6byo Member Since: 26 Dec 2008 Location: Italy Posts: 109 ![]() ![]() |
i can confirm.
buckblue Member Since: 30 Oct 2008 Location: Lebanon Posts: 144 ![]() ![]() |
what would i do without this forum!
"Hood open"?
hey bobby! first of all ur awesome help! well earned tech of the year!
If the hood switch is bad, no matter how tight you close the hood, the message "hood open" coming on and the alarm going off will occur as per the earlier link.
how do i know if its bad?
Well, if your hood is perfectly and tightly closed and it still says the hood is open, I would think the hood ajar switch is faulty and giving out the wrong message. |
