![]() | Home > Technical > Big problems with 2.7 diesel engine |
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 ![]() ![]() |
Thanks clutchdust, damn, mines an early '06, mind you it's hardly needed any oil at all, even at first, now done 18000miles, but it does sound a bit noisier (tappety) than others, and causes vibration through the whole car at idle, just doesn't seem as silky smooth as others I have driven. BBBB, Good Luck, and yeah, post some pics, and let us know how you get on. |
carranzad Member Since: 06 Aug 2010 Location: Buenos Aires Posts: 1 ![]() ![]() ![]() |
kupid0n Member Since: 26 Jun 2010 Location: oradea Posts: 30 ![]() ![]() ![]() |
sorry to hear that man! just for info....where did you take the car to? i have a good friend from hungary and my baby is there for the moment, getting its' smoking issue fixed. had the same problem with an nissan pathfinder, but luckily it was under waranty and they changed everything but the problem seemed to be unknown.....you know how our "specialists" do.....they just raise their shoulders and say...."i'm sorry...i don't know/can't help you" keep us informed! |
P44RY C Member Since: 30 Jun 2008 Location: Cheshire Posts: 22 ![]() ![]() ![]() |
Same problem here with the crankshaft breaking and firing debris into the engine, bent all the piston heads.
AlexMckie Member Since: 26 Nov 2009 Location: Devon Posts: 174 ![]() ![]() ![]() |
I know this may only be one option to you.....
4wheeldriver Member Since: 13 May 2009 Location: Aberdeen Posts: 955 ![]() ![]() ![]() |
It says its out of a Jag though Alex. Doesn't that mean a different sump?? Current, M135i in Estoril Blue with more extras than the cast of Ben Hur.
Yes that's right... Basically the engines are the same so there are only a few bits to swap over.....
BBBB Member Since: 31 Aug 2006 Location: Brasov Posts: 6 ![]() ![]() ![]() |
the service manager didn't have and still doesn't have any answers regarding this problem. when i look at the service history for both cars (we own 2 rrs 2.7 diesel) my personal opinion is that the cause is the really bad quality of this cars. |
Probably right. My RRS only had 80,000K on the clock when it happened to me. I had to get a new engine in the end which I managed to get for £2,200 with 34,000K on the clock. I had that fitted in December 2010 and so far its been ok. I have had other problems since then though whuch have needed fixing. Range Rover offered to pay a third of my engine cost in the end, BUT only on a new engine fitted by them. They wanted £8,000 all in to fit a new engine. So i was still much better off going and putting my own in for £2,200 |
