![]() | Home > Technical > Help electronic oil gauge!!! |
RRSSTEVE Member Since: 17 Jan 2010 Location: POOLE DORSET Posts: 15 ![]() ![]() ![]() |
stop fiddling and take it back to the dealer and ask the salesman to clean the dipstick |
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 ![]() |
Try checking it again when it's cold. I assume you followed:
cliff Member Since: 15 Oct 2009 Location: Kent Posts: 33 ![]() ![]() ![]() |
Cheers Steve,
Vadim Member Since: 20 Apr 2010 Location: London Posts: 855 ![]() ![]() ![]() |
Do what James suggests but wait at least 5-10 min after a run. Vadim A. |
Not sure what you unplugged but definitely not the oil sensor! I think on 2010MY vehicles, instead of a mechanical dipstick, an ultrasonic sensor is mounted to the underside of the oil pan where it sends an ultrasonic pulse vertically upward, and it then measures the time for the pulse to be reflected back from the top surface of the oil. This provides an electronic indication of the current oil level. Warnings will be displayed in the message center if the oil level is not maintained within the safe operating levels (minimum and maximum). A warning will also be displayed if there is a fault with the oil level monitoring system. ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
HI Bobby,James
