Home > Technical > Help electronic oil gauge!!!
cliff
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Nara Bronze
Hi All,
Just gone and checked the fluid levels (Monday ritual) and well twisted what i was told by Salesman was the dipstick and pulled off a 2" plug!,after a quick panic pulled out manual which now tells me it is all dealt with by electronics.my problem is that the system appears not to register that there is oil in the engine this i would imagine has been caused by me unplugging sensor,how can i get the thing working again!!.
Cliff Works well when WATCHED
Post #272809 Mon Aug 02 2010 5:51pm
RRSSTEVE
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
stop fiddling and take it back to the dealer and ask the salesman to clean the dipstick Laughing
the car should tell you when it needs oil . sounds like you found the oil vacuum pipe for oil changes.
Post #272834 Mon Aug 02 2010 9:14pm
Lookers Park Royal
Try checking it again when it's cold. I assume you followed:
Ignition On>
Menu>
Service Menu>
Oil Level>
If it says "Not Available" then it may be that the car is too hot at too much of an acute angle.
Hope this helps?
James Thumbs Up
Post #272853 Tue Aug 03 2010 7:31am
cliff
Cheers Steve,
I am back into the dealers today anyway,and yes should have read the manual before Checking levels!.i wasn't told that the car would tell me,just had the normal run through on the engine bay dipstick brake fluid etc...
Post #272854 Tue Aug 03 2010 7:37am
Vadim
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
Do what James suggests but wait at least 5-10 min after a run. Vadim A.
Post #272857 Tue Aug 03 2010 7:50am
Bobby
Re: Help electronic oil gauge!!!
cliff wrote:
.. me unplugging sensor .. Cliff
Not sure what you unplugged but definitely not the oil sensor!
I think on 2010MY vehicles, instead of a mechanical dipstick, an ultrasonic sensor is mounted to the underside of the oil pan where it sends an ultrasonic pulse vertically upward, and it then measures the time for the pulse to be reflected back from the top surface of the oil. This provides an electronic indication of the current oil level.
Warnings will be displayed in the message center if the oil level is not maintained within the safe operating levels (minimum and maximum). A warning will also be displayed if there is a fault with the oil level monitoring system.
Smile Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #272887 Tue Aug 03 2010 11:33am
cliff
HI Bobby,James
Thanks went into dealers and had one of the techs run me through it,So all sorted now thanks eveyone for the help.
Cliff Thumbs Up Works well when WATCHED
Post #273014 Wed Aug 04 2010 11:39am
