![]() | Home > Technical > my2006 suspension fault codes C1A34 & C1A38 |
Hmm.. Ideas..
alan turner Member Since: 24 Jul 2010 Location: teeside by the seeside Posts: 3 ![]() ![]() ![]() |
thanks for speedy reply there. forgot to mention that this is an intermitant problem but always comes up with same fault codes once light has illuminated. ill check the wiring first chance i get. im an audi mechanic but the systems on this baby are obviosly well different. excuse my ignorance but could you point me to the location of these 2 valves if possible/ thanks again alan |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
Got exactly the same fault (no idea about codes though) on my 2006 sport today, Yellow warning light and Normal Suspension height warning in the message centre, only 2000 KM's from home at the moment |
Hopefully this Schematic Pneumatic Circuit will help...
thanks very much for that bud, much appreciated. i`ll check over asap & let ya know. alan |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
Audi Mechanic, are you moonlighting on a RRS ![]() |
well it had one new Compressor fitted today, all is well for now, covered under the allianz extended warranty. Apparently it is near impossible to get hold of LR stock, so after markets are being fitted on those out of manufacturers warranty, most probably better quality than LR original parts after the shonky experience i have had with LR build quality over the last 4 years
If you don't know already, in addition to the compressor being replaced it is required that the air suspension control software is updated at the same time to ensure correct operation of the air suspension system. ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Cheers Bobby, will talk to the specialist tomorrow to see if they are aware, they are doing these on a regular basis they tell me, even those like BKHK's that never get off the tarmac |
Yes, it's TSB No.LTB00270 - Air Suspension Software Update When A Compressor Is Replaced |
bobby many thanks Another Pommie Bar Steward down under
diamond Member Since: 09 Feb 2009 Location: Dusseldorf, Germany Posts: 217 ![]() ![]() ![]() |
my 2009 RRS 2.7 is at the dealer as we speak due to suspension failure error. I just got the message that the air compressor is faulty and it will be replaced under warranty.
