Home > Technical > my2006 suspension fault codes C1A34 & C1A38
alan turner
HI ALL. YELLOW SUSP WARNING LIGHT ON WITH NORMAL SUSP HEIGHT ONLY WARNING. CHECKED DTC`S USING LAUNCH & CAME UP WITH CODES; C1A34 REAR RIGHT CORNER VALVE & C1A38 REAR CROSS LINK VALVE. ANY IDEAS MUCH APPRECIATED. ALAN
Post #272110 Sat Jul 24 2010 9:04pm
Bobby
Hmm.. Ideas..
C1A3401 - Right Rear Corner Valve
C1A3801 Rear Cross-Link Valve
In addition to general electric failure, causes can be:
a. Rear valve block disconnected
b. Rear valve block harness wiring short circuit to ground or high resistance
c. Right-hand rear corner valve failure/Rear cross-link valve failure
d. Air suspension control module failure
You would need to refer to the guided diagnostic routine for these codes on the approved diagnostic system.
Smile Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #272126 Sun Jul 25 2010 8:06am
alan turner
thanks for speedy reply there. forgot to mention that this is an intermitant problem but always comes up with same fault codes once light has illuminated. ill check the wiring first chance i get. im an audi mechanic but the systems on this baby are obviosly well different. excuse my ignorance but could you point me to the location of these 2 valves if possible/ thanks again alan
Post #272171 Sun Jul 25 2010 10:57pm
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Got exactly the same fault (no idea about codes though) on my 2006 sport today, Yellow warning light and Normal Suspension height warning in the message centre, only 2000 KM's from home at the moment Shocked
Hope its covered by the warranty Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #272172 Mon Jul 26 2010 3:46am
Bobby
Hopefully this Schematic Pneumatic Circuit will help...
 Malaysia Boleh!
Post #272194 Mon Jul 26 2010 11:26am
alan turner
thanks very much for that bud, much appreciated. i`ll check over asap & let ya know. alan
Post #272633 Fri Jul 30 2010 7:34pm
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Audi Mechanic, are you moonlighting on a RRS Question
Post #272644 Sat Jul 31 2010 5:49am
Zilch
well it had one new Compressor fitted today, all is well for now, covered under the allianz extended warranty. Apparently it is near impossible to get hold of LR stock, so after markets are being fitted on those out of manufacturers warranty, most probably better quality than LR original parts after the shonky experience i have had with LR build quality over the last 4 years
Mine was the 3rd Sport booked in this week with a compressor problem, 2 MY06 and 1 MY08 (poor sod has been lumbered with waiting for genuine parts and referred to their LR dealer not specialist company i use), wondering how big a problem the Compressors really are ... bigger than they will admit i bet.. Another Pommie Bar Steward down under
Post #272764 Mon Aug 02 2010 9:56am
Bobby
Zilch wrote:
well it had one new Compressor fitted today..
If you don't know already, in addition to the compressor being replaced it is required that the air suspension control
software is updated at the same time to ensure correct operation of the air suspension system
. Smile Malaysia Boleh!
Post #272771 Mon Aug 02 2010 10:27am
Zilch
Cheers Bobby, will talk to the specialist tomorrow to see if they are aware, they are doing these on a regular basis they tell me, even those like BKHK's that never get off the tarmac Whistle Laughing
Any detail on the code or revision for the Air Suspension Control Software Another Pommie Bar Steward down under
Post #272773 Mon Aug 02 2010 10:41am
Bobby
Yes, it's TSB No.LTB00270 - Air Suspension Software Update When A Compressor Is Replaced Wink Malaysia Boleh!
Post #272774 Mon Aug 02 2010 10:45am
Zilch
bobby many thanks Another Pommie Bar Steward down under
Post #272776 Mon Aug 02 2010 10:48am
diamond
Greece 2009 Range Rover Sport TDV6 SE Alaska White
my 2009 RRS 2.7 is at the dealer as we speak due to suspension failure error. I just got the message that the air compressor is faulty and it will be replaced under warranty.
The car is 16 months old with 30000km and I wonder if that happened now what I can expect in the future.
It's nice that LR gives 3 years warranty but it looks not enough. 2009 Range Rover Sport 2.7 TDV6 SE, Alaska White, Almond leather, tinted windows, active rear diff, tow pack, HiICE, full spare: gone and already missed
2004 Fiat Panda 1.2 Climbing 4x4
http://www.youtube.com/watch?v=fAg4DdXAp7Y
Post #277399 Wed Oct 06 2010 12:11pm
