Home > Maintenance & Modifications > Retrofit TPMS
avos
Retrofit TPMS
Anyone on the know if you can retrofit the original TPMS on a 2008MY RRS? Would be very interested to do so. RRS SDV6 HEV Dynamic
XKR 700 BHP with Twin-screw and LSD
Post #272222 Mon Jul 26 2010 6:55pm
Bobby
You will need :
1. 4 Initiators, one connected to each wheel arch. Each initiator has a connector which connects with the body harness.
2. 4 Tyre Pressure Sensors, each mounted in each wheel. The sensors will measure the pressure and temperature of the air inside the tyre and the measurements will be transmitted to the RF Receiver in the vehicle.
3. A TPMS Switch has to be added on in the centre console switch pack. You use this switch to set the pressures.
4. A TPMS Module, which will be located above the headliner of the vehicle. This module will monitor and detect all tyre pressures and also communicate with the vehicle instrument cluster to provide the driver with appropriate warnings that show the importance of the condition detected and indicate the status/failure of TPMS components.
5. Lastly, you will need to install/connect 2 warning indicators in the instrument cluster. One is for warnings conveyed by an amber LED warning indicator and another is a text message displayed in the message centre. The warning indicator and message centre are driven by CAN messages from the TPMS module.
You will of course need the proper connectors and wiring for the above and also set up the vehicle.
Still want to DIY? Smile Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #272268 Tue Jul 27 2010 8:52am
Tim in Scotland
And when you have finished you still have to take it into the dealer so it can all be enabled! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #272270 Tue Jul 27 2010 8:54am
Bobby
Laughing Laughing Laughing Thumbs Up Malaysia Boleh!
Post #272271 Tue Jul 27 2010 8:54am
Anybody use aftermarket TPMS which can also do the caravan tyres also?
Post #272284 Tue Jul 27 2010 9:42am
Rudskibaliblu
England 2012 Range Rover Sport SDV6 HSE Orkney Grey
I have just been reading about one called Trailair its by LR not out till august. Information comes up in your rear view mirror which comes as part of the kit, pricey though £650 plus fitting Shocked go to landrovertrailair.co.uk for more info. Now gone Orkney grey SDV6 HSE with body style kit contrast stitch ebony leather, privacy, black piano, 22" Lowenharts for summer, 20" with Leon LTZ for winter.
Here 110 black edition defender.
Post #272291 Tue Jul 27 2010 10:47am
Re: Retrofit TPMS
Avos i know you from the german Jaguar forum Laughing Twisted Evil
Post #272293 Tue Jul 27 2010 10:58am
avos
@Bobby,
Would still be interested to dig into this, tanks for the info so far.
@Tim,
Have the VCM, should that do the trick?
@Rudskibaliblu
Very interesting, will ook into this one also.
@XXXAngelXXX
Haven't heard you there fro a long time, though have to admit am not visiting to often anymore either. Let me know if you could use some extra horses Wink. RRS SDV6 HEV Dynamic
Post #272294 Tue Jul 27 2010 11:13am
Twisted Evil you cant get enough *horses* - but the SC has still a 2 year LR warranty on it Wink
Post #272297 Tue Jul 27 2010 11:32am
i've seen that, and have been waiting on it to be release to have a better look
Post #272302 Tue Jul 27 2010 12:13pm
Rudskibaliblu
For my sins i have a twin axle caravan still dont know if the outlay is justified enough, if a blow out occurs i will still have three wheels to bring it to a stop safely and the shredded tyre will have already caused the damage by then. Haven't had any problems up to now keep a close eye on pressures with a manual guage, think i'll see what the reviews are like. Now gone Orkney grey SDV6 HSE with body style kit contrast stitch ebony leather, privacy, black piano, 22" Lowenharts for summer, 20" with Leon LTZ for winter.
Post #272327 Tue Jul 27 2010 3:29pm
That were I have the worries Sad
Single axle and I have had a blow out, and I had also checked all my pressures due to length of journey
I just can't find anything reliable and with good reviews, and I would mind one that measures the temp also as ATS thought it might have been heat related
Post #272342 Tue Jul 27 2010 5:03pm
Rudskibaliblu
I've got over 3500 miles to put in over 3 weeks in france doing some reading into blowouts the temp normally increases with a low pressure tyre if this happens over a slow period of time ie slow puncture then i'm sure a pressure monitor with an alarm system if they have them? would give plenty of warning, unless something has lodged between wheel and axle to cause heat build up then nothing is going to stop it unless you see smoke and manage to pull over in time. I'm sure there must be something on the market it's all about cost at the end of the day i suppose. Thumbs Up Now gone Orkney grey SDV6 HSE with body style kit contrast stitch ebony leather, privacy, black piano, 22" Lowenharts for summer, 20" with Leon LTZ for winter.
Post #272357 Tue Jul 27 2010 7:30pm
quantz
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Bobby wrote:
You will need :
I have TPMS from factory on my 2010/TDV6. I'm about to buy a new set of rims which have TPMS valves.
Where are mounted the 4 initiators ? 2010 TDV6 3.0 HSE Santorini Black Tan Full Leather
Post #290692 Mon Feb 28 2011 11:46pm
Bobby
The TPMS has four initiators. Each initiator has a connector which connects with the body harness.
The initiators are located near the front of the front wheel arches and near the rear of the rear wheel arches and are secured with two scrivets.
Post #290695 Tue Mar 01 2011 1:12am
