![]() | Home > Maintenance & Modifications > Retrofit TPMS |
You will need :
And when you have finished you still have to take it into the dealer so it can all be enabled! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
Anybody use aftermarket TPMS which can also do the caravan tyres also? |
Rudskibaliblu Member Since: 05 Feb 2010 Location: Western lake district Posts: 329 ![]() ![]() ![]() |
I have just been reading about one called Trailair its by LR not out till august. Information comes up in your rear view mirror which comes as part of the kit, pricey though £650 plus fitting |
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 ![]() ![]() |
Avos i know you from the german Jaguar forum ![]() ![]() L 405 2013 FFRR 5.0 SC ![]() -------------------------------------------------------------- WINNER - 2009 �Best Avatar� Award WINNER - 2009 Comedian Of The Year Award |
avos Member Since: 26 Aug 2008 Location: Belgium Posts: 106 ![]() |
@Bobby,
i've seen that, and have been waiting on it to be release to have a better look |
For my sins i have a twin axle caravan still dont know if the outlay is justified enough, if a blow out occurs i will still have three wheels to bring it to a stop safely and the shredded tyre will have already caused the damage by then. Haven't had any problems up to now keep a close eye on pressures with a manual guage, think i'll see what the reviews are like. Now gone Orkney grey SDV6 HSE with body style kit contrast stitch ebony leather, privacy, black piano, 22" Lowenharts for summer, 20" with Leon LTZ for winter.
That were I have the worries |
I've got over 3500 miles to put in over 3 weeks in france doing some reading into blowouts the temp normally increases with a low pressure tyre if this happens over a slow period of time ie slow puncture then i'm sure a pressure monitor with an alarm system if they have them? would give plenty of warning, unless something has lodged between wheel and axle to cause heat build up then nothing is going to stop it unless you see smoke and manage to pull over in time. I'm sure there must be something on the market it's all about cost at the end of the day i suppose. |
quantz Member Since: 05 Mar 2010 Location: Paris, France Posts: 476 ![]() ![]() |
I have TPMS from factory on my 2010/TDV6. I'm about to buy a new set of rims which have TPMS valves. Where are mounted the 4 initiators ? 2010 TDV6 3.0 HSE Santorini Black Tan Full Leather |
The TPMS has four initiators. Each initiator has a connector which connects with the body harness.
