Home > Technical > HELP! Exhaust Gasket leaking TDV8 |
rrstdv8luxembourg Member Since: 15 Feb 2010 Location: Contern Posts: 30 |
Sat Jul 17 2010 1:52pm |
No, that's the problem |
Sat Jul 17 2010 3:39pm |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 |
What kind of idiot designs a car that you have to lift the whole body off to gain access to the exhaust gaskets, are these guy's on drugs!!! |
Sun Jul 18 2010 8:55am |
Which exhaust gasket? Can you be specific?
Sun Jul 18 2010 9:44am |
It is with DPF. The problem is where the exhaust is fixed on the engine. Due to high temperatures the material is deforming and so apparently a screw from the fixation is broken. Sorry for my english |
Thu Jul 22 2010 7:47pm |
Print THIS out and show it to your dealer.
Thu Jul 22 2010 9:07pm |
Thank you Bobby,
Fri Jul 23 2010 8:12am |
Thank you Bobby,
rrstdv8luxembourg,
Fri Jul 23 2010 9:45am |
jason.abel1 Member Since: 02 Jun 2012 Location: Norfolk Posts: 3 |
Hello.
Thu Aug 30 2012 2:40am |
DMike Member Since: 09 Nov 2007 Location: Perthshire Posts: 79 |
I can confirm, body off to drill out a broken manifold stud and/or replace the manifold gaskets
Sat Sep 01 2012 1:09pm |
bulletooth Member Since: 13 Aug 2012 Location: Berkshire Posts: 22 |
same thing happened to my friends TDV8 .. and he drilled of his studs out without removing the body .. cant remember how he did it , he had to modify some sort of drill bit to do it but he managed to get it done without removing the body anyhow |
Sat Sep 01 2012 2:16pm |
