Home > Technical > Headlight Unit Removal |
Details of how should be in your manual. 2005 Zambezi TDV6 - Gone but not forgotten
Wed Jul 14 2010 4:24pm |
gaz3014 Member Since: 02 Jan 2010 Location: Northants Posts: 69 |
Was hoping someone might have some top tips, I can use along with the manual!! Why wait till tomorrow, when today is already here!
Wed Jul 14 2010 6:12pm |
will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377 |
If they are the same as the older lights (>2009) there is a tab / clip each side which pulls up and the headlight just pops out. Easy! Even I have done it!! L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
Thu Jul 15 2010 12:10am |
When I had the LEDs done on my 2007 RRS the company that did the conversion told me that it was very easy to change them, just two clips to undo and they pop out BUT you must make sure that you have the keys out of the ignition as the lamps electrical ballast starts charging up as soon as they key is put into the ignition and there are a lot of volts and amps running through the lights units, so take care if you are going to remove the units yourself. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Jul 15 2010 7:05am |
Brilliant!!!! thanks very much guys. Why wait till tomorrow, when today is already here!
Thu Jul 15 2010 10:55am |
rrs2010 Member Since: 10 Feb 2010 Location: Leicestershire. Posts: 173 |
Remove the front grill first Cheers Paul
Thu Jul 15 2010 10:58am |
