Home > Technical > Headlight Unit Removal
gaz3014
Need a wee bit of help folks......can anyone tell me if there is a post on how to remove the headlight unit from an MY10?? Have done a search and can't find anything!!!!!!!! Sad
Cheers Why wait till tomorrow, when today is already here!
Gone: MY 10 RRS HSE, MY 12 RRS AB, MY 13 RR Evoque
Coming: MY 17 RRS AB
Post #271266 Wed Jul 14 2010 3:54pm
Details of how should be in your manual. 2005 Zambezi TDV6 - Gone but not forgotten
Post #271270 Wed Jul 14 2010 4:24pm
gaz3014
Was hoping someone might have some top tips, I can use along with the manual!! Why wait till tomorrow, when today is already here!
Post #271272 Wed Jul 14 2010 6:12pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
If they are the same as the older lights (>2009) there is a tab / clip each side which pulls up and the headlight just pops out. Easy! Even I have done it!! Mr. Green L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #271295 Thu Jul 15 2010 12:10am
Tim in Scotland
When I had the LEDs done on my 2007 RRS the company that did the conversion told me that it was very easy to change them, just two clips to undo and they pop out BUT you must make sure that you have the keys out of the ignition as the lamps electrical ballast starts charging up as soon as they key is put into the ignition and there are a lot of volts and amps running through the lights units, so take care if you are going to remove the units yourself. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #271303 Thu Jul 15 2010 7:05am
gaz3014
Brilliant!!!! thanks very much guys. Thumbs Up Why wait till tomorrow, when today is already here!
Post #271327 Thu Jul 15 2010 10:55am
rrs2010
Remove the front grill first Thumbs Up Cheers Paul
2006 TDV6 HSE - Cairns Blue
Tow Pack, Privacy Glass, PTI, DVD.
Post #271329 Thu Jul 15 2010 10:58am
