![]() | Home > Off Roading & Green Laning > 19" MT/R, Is that normal? (pic inside) |
llubi Member Since: 22 Dec 2009 Location: Barcelona Posts: 25 ![]() ![]() ![]() |
I bought that wheels two weeks ago, I only tested once in a sand climb, maybe 10 meters long, and 4 meters of height difference, and the wheels are like that:
I'll see if there are rocks, I think that there's only sand.
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
For Sand driving i would normally drop to 16-18 PSI, which is about 1.103 - 1.24 bar, that said i have noticed the odd nick in the tread as well, that is on Goodyear Wranglers HP, but nothing to worry about
I run my Def90 permanently on BFG MTRs and after a weekend offroading on gravel and flinty roads and in very muddy conditions with flinty stones in the mud they always end up with cuts like that. I ran it for a while on very aggressive Grizzly Claw tyres and even had several tread blocks and the side blocks cut off them in the same conditions - was annoying because if that happens the tyres are rendered illegal/ dangerous and I ended up replacing them with the BFG's. I was even able to sell the Grizzlies to a guy who trailered his 90 to offroad venues so missing tread blocks were not a problem for him! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
jimhardy7 Member Since: 29 Jul 2010 Location: ca Posts: 12 ![]() |
@Llubi: Maybe it’s not compatible with your car that’s why the tire is not bearing the weight and showing these massive cracks on the surface. |
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 ![]() |
Can I ask if they were new when you bought them? To me they look like they may be used tyres? If so then the higher pressures could have highlighted previous damage if the previous owner had been running them low for sand?
