Home > Off Roading & Green Laning > 19" MT/R, Is that normal? (pic inside)
llubi
Spain 2008 Range Rover Sport TDV8 HSE Java Black
I bought that wheels two weeks ago, I only tested once in a sand climb, maybe 10 meters long, and 4 meters of height difference, and the wheels are like that:
Then I think, if I go to hard off road, or rock climbing, these wheels will be killed in 2 months... Sad Sad
Thank's all!! Very Happy Very Happy Mr. Green
Post #260247 Sat Mar 20 2010 1:50pm
Leo
Kenya
What tyre pressure? Sometimes too much pressure increases the risk of cuts when off-road. Also, maybe you just hit a very sharp rock?
Post #260250 Sat Mar 20 2010 2:19pm
llubi
I'll see if there are rocks, I think that there's only sand.
The tires are at 2,7 in front and 2,8 at rear (bar pressure)
thank's!!
Post #260256 Sat Mar 20 2010 2:32pm
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
For Sand driving i would normally drop to 16-18 PSI, which is about 1.103 - 1.24 bar, that said i have noticed the odd nick in the tread as well, that is on Goodyear Wranglers HP, but nothing to worry about
Yesterday the vehicle when we were off roading was subject to a lot of rocks and loose stone, not an issue. Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #263346 Sat Apr 17 2010 11:59pm
Tim in Scotland
I run my Def90 permanently on BFG MTRs and after a weekend offroading on gravel and flinty roads and in very muddy conditions with flinty stones in the mud they always end up with cuts like that. I ran it for a while on very aggressive Grizzly Claw tyres and even had several tread blocks and the side blocks cut off them in the same conditions - was annoying because if that happens the tyres are rendered illegal/ dangerous and I ended up replacing them with the BFG's. I was even able to sell the Grizzlies to a guy who trailered his 90 to offroad venues so missing tread blocks were not a problem for him! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #270611 Wed Jul 07 2010 1:49pm
jimhardy7
@Llubi: Maybe it�s not compatible with your car that�s why the tire is not bearing the weight and showing these massive cracks on the surface.
Post #272606 Fri Jul 30 2010 1:31pm
Lookers Park Royal
Can I ask if they were new when you bought them? To me they look like they may be used tyres? If so then the higher pressures could have highlighted previous damage if the previous owner had been running them low for sand?
James Thumbs Up
Post #272615 Fri Jul 30 2010 2:28pm
