Home > Technical > Wind whistling through drivers door?
BIG DJ
I drove upto Carlisle this morning and noticed a very annoying wind whistling through the drivers door (door and window shut properly). Anyone had this issue before or know if this would be covered on lr extended warranty? It's not even windy at the moment so I dread to think what it will be like in the winter. Oh and this was only driving at 70mph.
Post #269648 Sat Jun 26 2010 1:09pm
sweetafton
England 2011 Range Rover Sport Supercharged Santorini Black
Have you checked you door rubber (seal). Might have a spilt in it. Has the door had any work done to it? Think should be covered on warranty but good luck. Thumbs Up
Post #269649 Sat Jun 26 2010 1:19pm
BIG DJ
Not sure about any work on work on it. Will have a closer look at the rubber.
Thanks Thumbs Up
Post #269650 Sat Jun 26 2010 1:30pm
Josh
Check the air vents as well TDV6 - gone
TDV8 - gone
Post #269883 Tue Jun 29 2010 3:54pm
BIG DJ
Question
Post #269893 Tue Jun 29 2010 4:53pm
anthony-apl
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
had the same with mine actually and it turned out to be the seal along the top of the windscreen. it had worked its way loose on the passenger side and the Whistle sound made me think it was form the passenger door. Might be worth checking this first Thumbs Up 16 model year yulong white autobiography
Bentley continental GTC
2011 VW Transporter T5 Kombi 140BHP with sport line kit for work
15 model year black RRS HSE gone
11MY Fuji White 3.0 TDV6 HSE
Ivory premium leather
Ebony contrast stitching
Extended leather pack
Anigra Wood now gone
08MY Range Rover Sport TDV6 GONE
Post #269935 Tue Jun 29 2010 10:36pm
Josh
BIG DJ wrote:
Question
I had this on one of mine......turned out to be the top FOS air vent. Turned fans off whistle went away TDV6 - gone
TDV8 - gone
Post #269980 Wed Jun 30 2010 10:07am
carlos50
I'm reviving this topic because i think i have the same problem with mine. I have checked the seals and although they are starting to peel they are not split. When i look along the A pillar on the drivers side the door frame is tight at the base of the glass but proud of the a pillar at the top of the door. This is echoed on the rear door on the drivers side.
Yesterday i pulled over because after hearing the wind noise and thinking the window was down i thought my drivers front door was open. It wasn't and the noise annoyed the heck out of my from that point on.
The passenger side is a very tight fit all around and is silent compared to the drivers.
I don't think its had any work / damage but cant say for sure, it just looks like its original and i am not a novice with bodywork fault finding.
Anyone know if its possible to adjust the door so its a tighter fit around the top which will form a better seal?
I'm going to replace the weather seals on the body of the car (the single seal that runs above both front and rear doors and is attached to the body not the doors) but want to have the doors realigned first.
Anyone ?
Thanks
Carl
Post #282725 Sat Dec 11 2010 10:49am
