![]() | Home > Technical > Wind whistling through drivers door? |
sweetafton Member Since: 05 Dec 2009 Location: Weymouth Posts: 961 ![]() ![]() ![]() |
Have you checked you door rubber (seal). Might have a spilt in it. Has the door had any work done to it? Think should be covered on warranty but good luck. |
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816 ![]() ![]() ![]() |
Not sure about any work on work on it. Will have a closer look at the rubber.
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
Check the air vents as well TDV6 - gone
anthony-apl Member Since: 07 Oct 2007 Location: sunny stockport Posts: 259 ![]() ![]() ![]() |
had the same with mine actually and it turned out to be the seal along the top of the windscreen. it had worked its way loose on the passenger side and the |
I had this on one of mine......turned out to be the top FOS air vent. Turned fans off whistle went away TDV6 - gone TDV8 - gone Audi Q5 3.0 Tdi Sline wef 6/11/10 |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 401 ![]() ![]() ![]() |
I'm reviving this topic because i think i have the same problem with mine. I have checked the seals and although they are starting to peel they are not split. When i look along the A pillar on the drivers side the door frame is tight at the base of the glass but proud of the a pillar at the top of the door. This is echoed on the rear door on the drivers side.
