![]() | Home > Technical > odd noise |
BBlackRRS Member Since: 31 Aug 2005 Location: US Posts: 40 ![]() |
Yes, you are correct, it is the weights. Probably one of the worst designs in balancing. IF you go over a speed bump at just the right angle, just under 5mph, the weights will will swing back and forth so hard that they will physically hit the rear bumper(inside the rear bumper).
wsy679 Member Since: 18 Jan 2006 Location: Bucks Posts: 50 ![]() ![]() ![]() |
I have been experiencing a noise from the O/S B pillar that when I go over any bump, drain cover or speed bump there is a dull thud coming from the area of the pillar, but it only seems to happen when the O/S wheels go over the bump, not all 4 wheels.
Robbi Member Since: 14 Jun 2005 Location: Channel Islands, Guernsey Posts: 130 ![]() ![]() ![]() |
Probably not the same thing but I found the passenger seat belt buckle is always tapping about the plactic on the pillar. Need to find a way to stop that.! Rob
Wish it was that simple. It happens even when the boss (her that should be obeyed) is in the passenger seat. At first I thought it it was the seat belt assembly inside the pillar beside me, but it is a rather solid clunk when it happens, but it does not sound if its from the back end.Will persevere and see how it goes. RRS HST Supercharged/ Stornoway Grey/Ivory/Piano Black/Sun Roof/Trackstar
Robbi, it's not the most elegant way to cure your tapping but I drive round with both the side belts buckled up........... that stops it! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it 2018 Melting Silver Mini Countryman PHEV - soon to be replaced 2015MY Corris Grey SDv6 HSE Dynamic, the best car I have ever owned, totally reliable only a cou0le of rattles in 3 years, now no longer in my care Also in my garage is a 1996 TDi300 Defender 90 County HT made into a fake CSW |
Zipperman19 Member Since: 22 Aug 2005 Location: South Florida Posts: 85 ![]() ![]() ![]() |
I fixed the plastic rattle fairly easiy. I Bought a sheet of think adhesive felt and cut thin strips to stick between the plastic frame and sliding belt adjuster. If you cut the pieces right you can even see them. Works like a charm. |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 ![]() ![]() |
And everyone welcome to the forum....Tony Hart |
Brocklebank Member Since: 10 Nov 2005 Location: Lake District Posts: 11 ![]() ![]() ![]() |
