![]() | Home > Technical > what is an ace rail ?????????? |
ELD70 Member Since: 19 Jan 2009 Location: UK Posts: 163 ![]() ![]() |
Never heard of it, you sure you got the spelling right...get them to email you maybe? |
airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248 ![]() ![]() |
That's what they put on there report something to do with the dynamic suspension maybe ace system ? |
TheDB Member Since: 07 Apr 2009 Location: Southerner Posts: 96 ![]() ![]() ![]() |
Isn't ACE the Active Cornering Enhancement. |
maybe thats what its called ?? thought someone may no ?
Don't know of rails connected to the Dynamic Response system... |
im as mifffed as you guys , they are quoting £1346 inc vat to replace ??
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Ask them ! Oh and get your £40 back whilst you are there - why did you pay if they did nothing to it |
Yes, if they want your money shouldn't they be answering your questions?
Ok I have found out that it's at the front
Worzel Member Since: 27 May 2009 Location: Lancashire Posts: 123 ![]() ![]() |
Mine 07 TDV6 HSe is in tommorow for the ace bar to be inspected by the warranty inspection guy.
worzel ,
like this one???
![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
If you confirm that the above drawing is what the dealer is referring to, then I believe you should refer them to an SSM issued by LR late last year. It refers to "Stabilizer Bar Fluid Weep" on Dynamic Response vehicles. I mentioned this in my first post above. The dealer has to correctly diagnose the leak path on the stabilizer bar to confirm if the leak is from the pipe o-rings, the stabilizer bar hydraulic seal or somewhere else. The pipe o-rings are serviceable parts and can be easily replaced. If its from the the hydraulic seal, then a new stabilizer bar will be needed. I would suggest you get it fixed fast! ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Mines making a hell of a noise and you can feel it feeding bacj through the steering wheel, and i think it effects the handling slightly.
