![]() | Home > Technical > what is an ace rail ?????????? |
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 ![]() ![]() |
Hope it all works out for you! |
Aww.. Angel! Don't say that!! ![]() ![]() Just contributing my two cents worth!! ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248 ![]() ![]() |
finally got to the butt of this , this is the ACE RAIL |
did pics go up ? |
HST Member Since: 05 Mar 2015 Location: Kirkby in Ashfield Posts: 9 ![]() ![]() ![]() |
My 09 MY HST has leaking rear ace bar. Main stealer quoted £1600 approx to swap it. Found out the Famous Four of Louth do a repair kit for front and rear bars. Quoted £250 to do both so its going in on Wed. Will post results. Said to work in 80/90 % of all cases. Now let me see £1600 v £250 which should I try. Oh and if it doesent work it can go onto a new bar so it will not leak!! Anyone had any experiance of this fix? |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9024 ![]() ![]() ![]() |
The repair kit probably just replaces the o-rings on the pipes. These are serviceable items. If it's leaking from the bar itslef then a new bar is required. And that's why the price is so high - the bar is expensive and I think it's 2-3 hours to replace if you know what you're doing and it goes well. 2012 SDV6 - it's missing a couple of cylinders
Apparently its not replacement of the seals, which as you say are replaceable in any event. This kit apparently involves additional brackets and the like. I will find out more on Wed and try and get photos. |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
I had the same issue with my frome ACE unit, however my Indie found that it wasnt leaking at all, and the oil was infact coming from a engine mount, appartently these are now oil filed, and damper controlled by a ecu 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
Job now done. Apparently what happens is that the bars themselves move in and out of the hydralic "can" in the middle. This can then affect the internal seals which start to leak. The kit that has been fitted to my HST consists of 4 clamps on the front bar and 2 on the rear. They reinforce the originals that move easily. Seal conditioner is then added to the fluid which of course swells the seals. I have included (I hope) which show the parts and fitting. Dont know if it works yet but a weekend dash across Germany and back will soon tell. Will report in due course. The front kit is £75 and the rear £45. 1 hour to fit and a tube of seal conditioner. So much cheaper than changing the bar.
Interesting. First time this fix has come up as far as I know.
My thoughts exactly Paddi. Fingers crossed that we've learnt of a cheap repair for the future... |
Dave435 Member Since: 14 Jul 2014 Location: Aberdeen Posts: 40 ![]() ![]() ![]() |
I've recently replaced my rear one due to it leaking. From what I've come across it's very common that they're moist but don't actually leak. Mine was leaking so I fitted a new one for peace of mind. |
