Home > Maintenance & Modifications > Psssttt.....mine grew 2 iches.... |
NightFox Member Since: 02 Mar 2010 Location: North Shropshire Posts: 381 |
It's not the wheel circumference, it's the tyre circumference that matters - has that changed? Alfa Romeo Giulietta 1.8::MG Montego Turbo::MGB GT::Rover Sterling::MGF::MG ZT 190+
Fri May 21 2010 2:25pm |
SkyWalker Member Since: 04 Sep 2009 Location: Marbella Posts: 538 |
Yes! You are completely right!
Fri May 21 2010 3:11pm |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 |
these were not standard size fit for RRS but Disco 3 so they were an oversize to begin with, standard RRS size is 255/55/18 Looks like you have now reverted to a standard RRS size in 20's so the speedo should read ok. 4.6 percent differnce sounds about right between the 2 sizes fitted on Disco 3 and RRS which is why you cannot mix the 2 sizes on a vechicle. I beleive their is a menu under the diagnostic mode on stat nav screen which can be changed for different sizes, this might of been done when the larger tyres were fitted |
Fri May 21 2010 8:38pm |
