Home > Maintenance & Modifications > Psssttt.....mine grew 2 iches....
SkyWalker
Netherlands 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Awww...sorry to disappoint you guys, also i don't have the answer to this secret. Crying or Very sad
But actually, i was talking about my wheels. Laughing
My RRS was delivered in 2005 with the ugly 18 inch alloys.
Those where replaced by 19' and 2 months ago by 20' 10 spokes. all wheels where dressed with normal road tires.
What a difference!!
And yes, i have not the dampened steering rack, and yes it drives perfectly without any shimmy or vibration what so ever. Cool
The question is: do i have to adjust the board computer (if possible) to display the correct distance/time/speed?
The circumference is different from the old wheels. When i do now 140 km/h it feels more like 120 km/h.
I know the difference can not be that big, but still..
Thanks
SW SW
Sometimes it is not enough to do our best;
sometimes we must do what is required.
Adriatic Blue 2005 RRS HSE 2.7 TDV6
Now: 2016 RRS HSE DYNAMIC 3.0 TDV6
Post #266809 Fri May 21 2010 1:01pm
NightFox
It's not the wheel circumference, it's the tyre circumference that matters - has that changed? Alfa Romeo Giulietta 1.8::MG Montego Turbo::MGB GT::Rover Sterling::MGF::MG ZT 190+
Discovery Series II Td5 GS::Discovery 3 TDV6 S::Freelander 2 TD4 XS::Freelander 2 TD4 SE
Zermatt Silver Range Rover Sport TDV6 3.0
Post #266815 Fri May 21 2010 2:25pm
SkyWalker
Yes! You are completely right! Embarassed
The original 18' wheels had 255/60R18 tires and the current 20' wheels have 275/40R20 tires.
After an internet search, i found this link: http://www.landroverwinkel.nl/My_Homepage_Files/Page9.html
It calculated a difference between the old in circumference of - 11.06 cm (!!!! Shocked !!!!!) per tire (- 4.61%)
This gives an reel speed of 95.39 km/h at 100 km/h indicated.
So at 140 km/h indicated, the actual speed is 133.55 km/h.
Also per 100.000 driven km's, i get a "discount" of 4610 km's!! since the cars odometer only indicates 95.390 km.
So is there a way to correct the cars system to the new circumference of the tires? Via board computer, or dealer software update? SW
Post #266821 Fri May 21 2010 3:11pm
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
these were not standard size fit for RRS but Disco 3 so they were an oversize to begin with, standard RRS size is 255/55/18
Looks like you have now reverted to a standard RRS size in 20's so the speedo should read ok.
4.6 percent differnce sounds about right between the 2 sizes fitted on Disco 3 and RRS which is why you cannot mix the 2 sizes on a vechicle.
I beleive their is a menu under the diagnostic mode on stat nav screen which can be changed for different sizes, this might of been done when the larger tyres were fitted
Post #266869 Fri May 21 2010 8:38pm
