Home > Technical > 2.7 TDV6 Engine start up......rough!
accyis
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Hi please help.
My 2005 TDV6 starts in the mornings like it's miss firing (runs lumpy for a short period) then settles down. I always wait for the glow plug symbol to dissapear before starting. At the main dealers an EGR valve had been replaced recently, a full service the same week and then i sent it back in again for further checks on the other EGR valve and glow plugs etc. They said they were fine and all the vehicle required was a computer udpdate.
I trusted them, but feel like i have been fobbed off (yet again) as the problem still persists, some days worse than others.
Every vehicle i have ever owned i have been able to turn the ignition key and the engine fire up immediately, even without having a foot on the accelerator. With this RRS i literally need to have the accelerator pressed half way for it to fire (even then its lump)
Is this part of owning an RRS?
Post #265692 Tue May 11 2010 7:37am
RichardM
2010 Range Rover Sport TDV8 HSE Galway Green
I didn't think in any modern car you should have to press the accelerator to start the engine. This can't be right. Is there another local dealer you can try? WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
2010 TDV8 HSE Galway Green - Adaptive Cruise - Sunroof - Privacy Glass - 5 Spoke Alloys
2009 TDV6 3.0 HSE Buckingham Blue - GONE
Post #265697 Tue May 11 2010 8:26am
Jonny Fresh
accyis.....that is NOT right.......where in Lancs are you? Stratstones in Bury are good.
Post #265698 Tue May 11 2010 8:46am
accyis
My thoughts exactly...
This is my first Land Rover and purchased through 'Hillendale' just off the M65 in Lancashire. I've been back with lots of silly problems all covered under the extended warranty but this problem doesn't appear to be getting solved.
Once the car has fired up for the first time that day, there is no problem therafter. Its so frustrating! I don't want to be viewed as a moaning ba Censored rd by the dealership, i'd just like to feel confident taking it back and the issue sorted out, whatever it may be.
Any advice on the fault or does anyone recommend another dealership local to my area (Lancashire)
Post #265699 Tue May 11 2010 8:46am
Jonny Fresh
Stratstones Bury half an hour from M65
Post #265700 Tue May 11 2010 8:50am
accyis
Thanks Jonny Fresh, we must have been typing at the same time....
With regards to the fault, does anyone have any idea what could be the cause of this?
Also, if taken to a different LR dealership, would the work (subject to warranty conditions) be covered?
Post #265701 Tue May 11 2010 8:56am
Jonny Fresh
Should definitely be under warranty.....best person to deal with in Service at Bury is Barrie
Post #265702 Tue May 11 2010 9:19am
RichardM
If its only the first time its started you should ask the dealer to keep it overnight so that they can experience it. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
Post #265706 Tue May 11 2010 9:52am
accyis
Hi Richard thanks for your response.
I did let them keep it for 3 days in which time the technician said he experienced on the vehicle what i was talking about. However, he states the EGR valves and glow plugs and all connections are fine and that it took a software download update. I felt at the time it was a load of bull, but you put trust in these organisations.
Should i be taking it back asking for further investigation or cut my losses and take the vehicle elsewhere?
I would like to assume it would be covered under the extended warranty.
Post #265708 Tue May 11 2010 10:04am
Bobby
There was a very old TSB on such an issue (2007, I think).
Basically it was concerning TDV6 engines whose idle quality is poor for 10 to 25 seconds after starting from cold for the first time during the day. After that it will be OK the whole day!
This was attributed to contamination (debris/dirt or corrosion) in the fuel injectors. Apparently this affects injector spray and delivery rate. An injector with damaged internal sealing will also result in unmetered fuel entering the intake manifold.
This is a fuel problem. The fuel tank need to be cleaned and fuel filter changed. If the problem still persists, the fuel injectors need to be checked for flow rate etc.
Not sure if this will help but...call me numpty! Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #265715 Tue May 11 2010 11:15am
You never cease to amaze me Bobby. Thumbs Up 2005 Zambezi TDV6 - Gone but not forgotten
Post #265717 Tue May 11 2010 11:51am
accyis
Thanks bobby
What's a TSB?
If this proved to be the reason would this work be covered under warranty?
Post #265718 Tue May 11 2010 11:51am
accyis
Also, It's just been serviced at 57k. Would the fuel filter have been changed at this service?
Post #265720 Tue May 11 2010 12:19pm
RichardM
Its a service bulletin for the garage. I would have thought if you have an extended warranty then this should covered whatever it takes to get it fixed. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
Post #265722 Tue May 11 2010 1:02pm
Bobby
I don't know if you'll be able to claim warranty.
Anyway, have just looked my notes - this TSB is LTB00047v2 and it covers
2.7L (TDV6) Diesel Engines, VIN-range: 5A900505-6A966000.
Good luck! Wink Malaysia Boleh!
Post #265733 Tue May 11 2010 2:21pm
