![]() | Home > Technical > 2.7 TDV6 Engine start up......rough! |
RichardM Member Since: 25 Sep 2009 Location: Herts Posts: 745 ![]() ![]() |
I didn't think in any modern car you should have to press the accelerator to start the engine. This can't be right. Is there another local dealer you can try? WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
accyis.....that is NOT right.......where in Lancs are you? Stratstones in Bury are good. |
accyis Member Since: 06 Feb 2010 Location: Lancashire Posts: 109 ![]() ![]() ![]() |
My thoughts exactly...
Stratstones Bury half an hour from M65 |
Thanks Jonny Fresh, we must have been typing at the same time....
Should definitely be under warranty.....best person to deal with in Service at Bury is Barrie |
If its only the first time its started you should ask the dealer to keep it overnight so that they can experience it. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
Hi Richard thanks for your response.
There was a very old TSB on such an issue (2007, I think).
You never cease to amaze me Bobby. |
Thanks bobby
Also, It's just been serviced at 57k. Would the fuel filter have been changed at this service? |
Its a service bulletin for the garage. I would have thought if you have an extended warranty then this should covered whatever it takes to get it fixed. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
I don't know if you'll be able to claim warranty.
