![]() | Home > Maintenance & Modifications > Problem with removable Tow Ball |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
I can't seem to get my removable Tow Ball unit to fit into the receptor. It goes in and appears to click in place
purple people eater Member Since: 10 Dec 2009 Location: Miles beyond midlife crisis Posts: 990 ![]() ![]() |
Not lost a Caravan yet |
Well actually yes, i did drop one outside my drive once when i had not correctly secured the hitch, but not on a RRS |
Finally got the damn thing to locate properly! Took much pushing & wiggling and a few choice words combined with a kick & then it suddenly clicked in to place. |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
Its a fight everytime you want to fit it or take it off.
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 ![]() ![]() |
Lespes, in case you weren't aware, the key should not be able to be removed from the lock unless tow hook is fitted,(or you trigger it as if it were fitted), and in the locked position. |
Yep, It's a real B |
no its all OK. Always remove key when putting back in storage, thats how it came ![]() If leave key in will not fit in my storage place, to big, sometimes its a peice of cake , more often not ![]() |
