![]() | Home > Technical > Depressurizing the air spring |
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 ![]() ![]() |
There are a few posts on www.disco3.co.uk describing how to change the shocks. Might take time searching for them, but they're there somewhere. |
jetblasters Member Since: 09 Oct 2007 Location: Heathrow Posts: 31 ![]() ![]() |
if you can borrow a Hawkeye or similar you can command the car to drop all the air out of the system completely.
Micrometer Member Since: 26 Nov 2009 Location: Cambridge Posts: 39 ![]() ![]() ![]() |
i would'nt change the dampers if you have ARC fitted as the roll rate will change and confuse the ecu however.. the easiest way to depressurise is to drop to access, disconnect the battery then jack the vehicle up high to drop the spring pressures then slowly and carefully unscrew the voss connectors in the valve blocks that feed the springs when they start hissing just leave them alone to deplete the air, dont rush this as the voss connectors are very easy to thread in the valve block (£££). i'd wear safety glasses etc when doing this incase the connector whips about. when its stopped hissing crack them off abit more and leave again etc.. Trust me, i'm an Engineer! |
avartis Member Since: 10 Sep 2009 Location: UK Posts: 18 ![]() ![]() |
I don't think I have ARC as my option doesn't include Dynamic Response. |
Don't worry - even if you do have arc/dr, it doesn't make a difference. The Bilsteins are good (but the B6 is not recommended for cars with dr) as are Koni and the Greek Spyros ones. It's a quick job once you find the instructions. |
Be careful, check with the manufacturers.
Leo,
Yes,
