Home > Technical > Depressurizing the air spring
avartis
2006 Range Rover Sport TDV6 SE Rimini Red
Hello,
I ordered some billstein b6 offroad shock absorbers and plan to replace the OEM shocks. Is there any easy way to depressurize the airbag ?
I plan on lowering the car into access mode so the air pressure is low and remove vauss connector and hope everything will be fine.
If you know of any easier way to do this it will be much appreciated
Post #264912 Mon May 03 2010 9:53am
Leo
Kenya
There are a few posts on www.disco3.co.uk describing how to change the shocks. Might take time searching for them, but they're there somewhere.
Post #264945 Mon May 03 2010 6:05pm
jetblasters
2005 Range Rover Sport TDV6 Java Black
if you can borrow a Hawkeye or similar you can command the car to drop all the air out of the system completely.
Stuart
Post #265186 Thu May 06 2010 6:23am
Micrometer
United Kingdom 2010 Range Rover Sport Supercharged Java Black
i would'nt change the dampers if you have ARC fitted as the roll rate will change and confuse the ecu however.. the easiest way to depressurise is to drop to access, disconnect the battery then jack the vehicle up high to drop the spring pressures then slowly and carefully unscrew the voss connectors in the valve blocks that feed the springs when they start hissing just leave them alone to deplete the air, dont rush this as the voss connectors are very easy to thread in the valve block (£££). i'd wear safety glasses etc when doing this incase the connector whips about. when its stopped hissing crack them off abit more and leave again etc.. Trust me, i'm an Engineer!
Post #265344 Fri May 07 2010 10:14am
avartis
I don't think I have ARC as my option doesn't include Dynamic Response.
Post #265608 Mon May 10 2010 11:16am
Leo
Kenya
Don't worry - even if you do have arc/dr, it doesn't make a difference. The Bilsteins are good (but the B6 is not recommended for cars with dr) as are Koni and the Greek Spyros ones. It's a quick job once you find the instructions.
Post #265628 Mon May 10 2010 1:33pm
Bobby
Be careful, check with the manufacturers.
I think it is not compatible with ACE. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #265661 Mon May 10 2010 7:41pm
Micrometer
Leo,
Changing the damper characteristic does make a difference to DR, it has to. DR uses accelerometers that measure lateral and longtitudinal accelerations so if different dampers change the roll rate then the signals to the DR system must be different and therefore the system will act differently, whether you or i could tell a difference when driving normally is irrelavent - i wouldnt do it because i dont know what these changes would mean when trying to avoid a stationary car on the motorway whilst doing 70mph. Just my opinion you understand!! Trust me, i'm an Engineer!
Post #265689 Tue May 11 2010 7:14am
avartis
Yes,
they are not ACE (Active cornering enhancement) compatible.
From my understanding, the Dynamic Response option is what ACE refers to. As I don't have dynamic response fitted on my RRS, I should be fine.
Post #265755 Tue May 11 2010 5:45pm
