Home > Technical > Sat Nav Aerial - where is it?
robinc
United Kingdom 2010 Range Rover Sport 3.0 TDV6 SE Nara Bronze
Answering my own question, the blue connector in the photo above is the GPS aerial. I've now disconnected this and connected the end of the cable to a £10 magnetic mount GPS aerial which I've placed just behind the sharks fin. The cable from the new aerial is routed into the headlining space through a conveniently located rubber bung that was already there. Job done and all working as it should. Thanks for all the input guys, saved me a lot of time Very Happy
Post #264760 Fri Apr 30 2010 1:25pm
Shrinky
Sorry robin haven't been on for a few days and only just read this Embarassed Glad you got it sorted Thumbs Up Global Warming.... I'm luvvin it.
Post #265173 Wed May 05 2010 9:38pm
MIKEB
England 2006 Range Rover Sport TDV6 HSE Rimini Red
Re: Sat Nav Aerial - where is it?
robinc wrote:
Hi guys
Been having intermittent problems with my satnav for a while. Keeps losing the GPS signal, especially when it's raining. Having fiddled around with every connection and even changed the DVD disk, I eventually bought a cheap after-market magnetic GPS aerial, stuck it on the roof and plugged it into the back of the satnav unit under the passenger seat in place of the normal aerial connection. Bingo, everything working perfectly again Very Happy
Whilst this has temporarily fixed the problem, I would like to locate the original GPS aerial and fix it or replace it. I heard a rumour that it's somewhere in the tailgate spoiler?
Does anyone know if that's correct and if so, how to gain access? I can't see any easy way to get into the spoiler but maybe I'm missing something obvious.
Any tips gratefully received.
Jusy been advised to look at your problem as I am having similar Do you remember where you got your after market cheap gps arerial from
Robin
Post #383808 Wed May 22 2013 3:41pm
Paddi
Mike, you need to type your post after the quote marks or it will be included in the quote. Suspect the poster is no longer active on this forum. There are v. cheap aerials on eBay like this one: http://www.ebay.co.uk/itm/Car-Aerial-GPS-N...0760260394
But.. it is from Hong Kong so might take 3 weeks to arrive and then not work anyway Rolling with laughter
Similar looking aerials are available on Amazon and Maplin's for about £20 which seems a lot to spend on diagnosing a fault. Before you buy a test aerial it might be worth having a closer look at the shark fin especially where the cable joins it. That's the most obvious place for a problem to have occurred. 2008 MY Java Black TDV8 HSE
Post #383883 Thu May 23 2013 11:48am
flydive
MAW wrote:
Bobby wrote:
Your BT phone module is hidden between the headliner and the roof. Wink
Thank you Thumbs Up
Negative, the BT module is in the boot, right side, behind the side panel. '08 RRS TDV8
Post #383891 Thu May 23 2013 12:43pm
Bobby
flydive wrote:
MAW wrote:
Thank you Thumbs Up
MAW wrote..
Quote:
My current RRS is a MY09 but it is the shallower fin - if the BT is not in there now where is it?
 Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #383940 Thu May 23 2013 8:57pm
flydive
Exactly. As I said, the BT module is in the boot, behind the right hand panel. Thumbs Up '08 RRS TDV8
Post #383951 Thu May 23 2013 10:59pm
DerrekL
I have the red line through GPS so bought aftermarket GPS aerial, just plugged it in but still red line showing Sad any further options I could check or does anyone know if there is anything to do after plugging new aerial in? i.e. hard reset so aerial is picked up. Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #505937 Tue Sep 20 2016 4:33pm
DerrekL
All good now... jumped into car this morning and GPS all working fine. Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #505983 Wed Sep 21 2016 8:43am
