![]() | Home > General > looking for some buying advise |
Mountain_Rover Member Since: 01 Mar 2010 Location: U.S.A. Posts: 15 ![]() ![]() |
From my experience you need to check the following:
NickM Member Since: 14 Feb 2008 Location: London Posts: 2995 ![]() ![]() |
Truck??? It's a car man!!!!!!! A CAR!!!!!!!! |
Dougaldog Member Since: 07 Apr 2010 Location: South Posts: 2 ![]() |
Thanks for the info so far..
Mate only some cars have it - but you see posts on here about it - just slight knocking sounds from the front suspension when going over bumps in the road etc.
If I'm not mistaken, the knock is only found in those RRSports with the dynamic suspension option. It is standard on all supercharged models here in the USA, and I think it is an option on HSE versions. I do experience the knock, but only under certain conditions: at low speed (less than 10 mph) while making a turn on a bumpy road. |
Rob Powell Member Since: 24 Sep 2009 Location: Staffordshire Posts: 10 ![]() ![]() |
I was in the same situation.
