![]() | Home > Technical > Suspension raising to extended mode????????? |
What happens if you press the offroad height end of the switch - it is a rocker switch, one end to offroad and the other to access. It isn't a push push type switch 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
accyis Member Since: 06 Feb 2010 Location: Lancashire Posts: 109 ![]() ![]() ![]() |
I know. The access mode has worked fine since owning the car. Just yesterday and today the vehicle automatically raises into extended mode even though the access mode has been selected and the started lowering. Suddenly raising to extended mode. Very strange. All info welcome. |
Is the car very dirty underneath or have you been offroad in the last few days? I think a trip to the dealer might be coming up if the car isn't dirty underneath. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
I'll give it a wash and post it's response |
deadly Member Since: 29 Nov 2008 Location: lancashire Posts: 9 ![]() ![]() ![]() |
Hi Accy, did you get it sorted???
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
I thought i had posted on this - must be another thread - height sensor |
Well all. here goes.
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
what happens when you select off road height |
All other suspension functions work correctly. If i was very critical i would say it sits a touch high at the rear and feels a little harsh on the back compared to how i remember the magic carpet. |
Wonder if the sensors that sense something underneath the car and put it into extended mode are being tricked either by being faulty or perhaps covered in muck, not sure where or how they work, but if other modes are working ok then this might be cause. |
hario69 Member Since: 06 Jan 2009 Location: Teesside Posts: 68 ![]() ![]() |
I have exactly the same problem and had a rear height sensor diagnosed, replaced but still doing it
Hi all. Quick update about the problem. They struggled with it for a while and then ended up replacing the compressor. The problem has been removed. Hopefully it will stay that way. My only point I don't understand is that if the compressor had failed why would the car raise to extended mode every time I selected access mode. Strange! |
marvelaugusts Member Since: 02 Apr 2010 Location: uk Posts: 4 ![]() ![]() |
Sounds like you just need the suspension calibrating. If normal height is too low at any one corner, when you go to access mode, it will hit the bump stops and shoot up to extended. m3 card |
avartis Member Since: 10 Sep 2009 Location: UK Posts: 18 ![]() ![]() |
I have the same issue. I know for a fact my shock absorbers inside the air struts are bad (lots of rolling and swaying and noises at very low speeds when hitting bumps, not the anti roll bushes).
