Home > Technical > Suspension raising to extended mode?????????
accyis
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
When parking and pressing the access mode on the suspension it automatically raises to extended mode. Why? Please help....
Post #256881 Mon Feb 22 2010 8:41pm
Tim in Scotland
What happens if you press the offroad height end of the switch - it is a rocker switch, one end to offroad and the other to access. It isn't a push push type switch 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #256891 Mon Feb 22 2010 9:20pm
accyis
I know. The access mode has worked fine since owning the car. Just yesterday and today the vehicle automatically raises into extended mode even though the access mode has been selected and the started lowering. Suddenly raising to extended mode. Very strange. All info welcome.
Post #256901 Mon Feb 22 2010 10:05pm
Tim in Scotland
Is the car very dirty underneath or have you been offroad in the last few days? I think a trip to the dealer might be coming up if the car isn't dirty underneath. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #256902 Mon Feb 22 2010 10:06pm
accyis
I'll give it a wash and post it's response Thumbs Up
Post #256912 Mon Feb 22 2010 10:51pm
deadly
Hi Accy, did you get it sorted???
ive just had 7 weeks in landrover with same issue and no solution.
regards Chris
Post #261891 Sat Apr 03 2010 5:10pm
MAW
I thought i had posted on this - must be another thread - height sensor Thumbs Up
Post #261893 Sat Apr 03 2010 5:14pm
deadly
Well all. here goes.
2006 rrs. When select access it goes down, ...ping....... extended mode flashes up n up she goes.
Sreen says extended mode then remove obstruction.
LR had it 7 weeks this year and 3 weeks last year,replaced height sensors (3times) compressor(3 times),ecu (twice),valve block, balance valve
They said no faults,.. computer says no.
All hardware changed, so im told.????
wiring fault???
Well computer says no short cicuit n no open circuit,ie broken wires.
Im at a loss.
So LR said try a different dealer.
I looked under vehicle n its not even been steamed off, which i would have expected.
Im not without mechanical experience so hit me with your ideas.
Kind regards Chris.
Post #261894 Sat Apr 03 2010 5:25pm
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
what happens when you select off road height Question
Post #261979 Sun Apr 04 2010 11:35am
deadly
All other suspension functions work correctly. If i was very critical i would say it sits a touch high at the rear and feels a little harsh on the back compared to how i remember the magic carpet.
Post #262034 Mon Apr 05 2010 11:08am
lespes
Wonder if the sensors that sense something underneath the car and put it into extended mode are being tricked either by being faulty or perhaps covered in muck, not sure where or how they work, but if other modes are working ok then this might be cause.
Post #262036 Mon Apr 05 2010 11:20am
hario69
I have exactly the same problem and had a rear height sensor diagnosed, replaced but still doing it
You can press into access mode, wait for extended mode on dash then press again and it overrides it - no mucky offroad on underside so its a mystery!
Post #262053 Mon Apr 05 2010 2:25pm
accyis
Hi all. Quick update about the problem. They struggled with it for a while and then ended up replacing the compressor. The problem has been removed. Hopefully it will stay that way. My only point I don't understand is that if the compressor had failed why would the car raise to extended mode every time I selected access mode. Strange!
Post #262086 Mon Apr 05 2010 7:45pm
marvelaugusts
Sounds like you just need the suspension calibrating. If normal height is too low at any one corner, when you go to access mode, it will hit the bump stops and shoot up to extended. m3 card
Post #262223 Wed Apr 07 2010 5:13am
avartis
2006 Range Rover Sport TDV6 SE Rimini Red
I have the same issue. I know for a fact my shock absorbers inside the air struts are bad (lots of rolling and swaying and noises at very low speeds when hitting bumps, not the anti roll bushes).
Now let me explain what happens:
The car doesn't lower at the same rate front and back (my front shocks are shot) so the car thinks it's hitting an obstacle underneath. You can spot this easily when you raise/lower the supspension.
For example, I left my RRS parked for a week now. The back has lowered (as it should be), the front is at normal height because the damaged shocks prevent it from lowering even after a week.
I think many more people have to take into account this posibility when having this problem. It's not always sensors or air suspension problems.
Post #266319 Mon May 17 2010 2:07pm
