Home > Technical > Jacking up
BAWSACK
Scotland 2008 Range Rover Sport TDV8 HSE Zermatt Silver
Jacking up
I'm going to be refurbishing my calipers on my 58 plate TDV8 in the near future, was just wondering if there's any issues with jacking the thing up with all 4 wheels clear of the ground? I was just going to select the offroad position and then continue to jack up with 3 tonne trolley jack until car is on stands and all 4 wheels can be removed - is this the correct method and will it cause any problems the height sensors etc Question
Any advice would be most appreciated Thumbs Up
Post #260581 Tue Mar 23 2010 12:26am
RichardM
2010 Range Rover Sport TDV8 HSE Galway Green
Why put it into off-road mode first? Doesn't that just mean the jack has to extend even further? WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
2010 TDV8 HSE Galway Green - Adaptive Cruise - Sunroof - Privacy Glass - 5 Spoke Alloys
2009 TDV6 3.0 HSE Buckingham Blue - GONE
Post #260695 Tue Mar 23 2010 9:35pm
BAWSACK
I just thought this is normal procedure before jacking, remember reading something stating that you had to do this first Question
This is whay I ask, just not sure and don't want to screw anything up
Post #260697 Tue Mar 23 2010 9:54pm
MAW
Correct - off road first
Post #260698 Tue Mar 23 2010 9:55pm
RichardM
Do you know why this is? WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
Post #260705 Tue Mar 23 2010 10:57pm
Josh
Cos if you don't you'll never get the wheels off the ground until you've raised the suspension to offroad height with the jack by which time it's unlikely the jack will have any lift left.
Lock it in off road height first and you haven't got the issue cos the suspension is already raised to near its max height. TDV6 - gone
TDV8 - gone
Post #260706 Tue Mar 23 2010 11:01pm
Bobby
Have you read your vehicle manual?
This is an extract from the Wheels and Tyres section......
WARNINGS
1. Always find a safe place to stop, off of the highway and away from traffic.
2. Ensure that the vehicle is on firm level ground.
3. Disconnect any trailer/caravan from the vehicle.
4. Switch on the hazard warning lamps.
5. Ensure that all passengers and animals are out of the vehicle and in a safe place away from the highway.
6. Place a warning triangle at a suitable distance behind the vehicle, facing towards oncoming traffic.
7. Ensure that the suspension is set to off-road height.
8. Ensure that the front wheels are in the straight ahead position and engage the steering lock. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #260709 Tue Mar 23 2010 11:17pm
Josh
You forgot
9. Call LR assist TDV6 - gone
TDV8 - gone
Post #260711 Tue Mar 23 2010 11:20pm
RichardM
Shouldn't that be
1. Call LR assist
They must be used to it given the number of women who drive RRS's around here! WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
Post #260712 Tue Mar 23 2010 11:39pm
BulletProofBomb
Took mine into Kwik-Fit recently to have a slow puncture looked at and he asked me to lock it into access height???? Should I smack him in the head next time, and tell him not to be so stupid? I just assumed they knew what they were doing. Iknow, Iknow, Kwik-Fit knowing what there doing is an oxymoron.
Bullet
Post #260714 Wed Mar 24 2010 12:20am
NightFox
Surely the jack only has the same maximum lift height irrespective of how the car gets to offroad height? Confused Alfa Romeo Giulietta 1.8::MG Montego Turbo::MGB GT::Rover Sterling::MGF::MG ZT 190+
Discovery Series II Td5 GS::Discovery 3 TDV6 S::Freelander 2 TD4 XS::Freelander 2 TD4 SE
Zermatt Silver Range Rover Sport TDV6 3.0
Post #260730 Wed Mar 24 2010 7:44am
MAW
Correct but I think Josh means you'd know that without having to lift the vehicle full travel to find out - issue with some trolley jacks, obv the LR jack travels far enough but it is certainly easier to get to height without the load on...
Post #260738 Wed Mar 24 2010 8:49am
NightFox
Ahh, makes sense. Alfa Romeo Giulietta 1.8::MG Montego Turbo::MGB GT::Rover Sterling::MGF::MG ZT 190+
Post #260739 Wed Mar 24 2010 8:50am
NightFox
Actually, thinking about it, what Kwikfit said would seem to make more sense; with the car locked at access height surely you wouldn't have to jack the chassis as high before the wheels were clear of the ground (assuming they don't just "dangle"). You might have a jack that wouldn't be able to lift the car when the suspension was fully extended, but it should be able to if in access mode.
Yes I know that the manual says to use extended, but do you see my point? Alfa Romeo Giulietta 1.8::MG Montego Turbo::MGB GT::Rover Sterling::MGF::MG ZT 190+
Post #260741 Wed Mar 24 2010 8:56am
MAW
No - i think locking is only an electronic and temporary overide - they would mechanically fall under gravity IIRC
Post #260742 Wed Mar 24 2010 8:58am
