Home > Technical > Jacking up |
RichardM Member Since: 24 Sep 2009 Location: Herts Posts: 745 |
Why put it into off-road mode first? Doesn't that just mean the jack has to extend even further? WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
Tue Mar 23 2010 9:35pm |
BAWSACK Member Since: 12 Jan 2010 Location: Falkirk Posts: 18 |
I just thought this is normal procedure before jacking, remember reading something stating that you had to do this first
Tue Mar 23 2010 9:54pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Correct - off road first |
Tue Mar 23 2010 9:55pm |
Do you know why this is? WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award 2010 TDV8 HSE Galway Green - Adaptive Cruise - Sunroof - Privacy Glass - 5 Spoke Alloys 2009 TDV6 3.0 HSE Buckingham Blue - GONE |
Tue Mar 23 2010 10:57pm |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 |
Cos if you don't you'll never get the wheels off the ground until you've raised the suspension to offroad height with the jack by which time it's unlikely the jack will have any lift left.
Tue Mar 23 2010 11:01pm |
Have you read your vehicle manual?
Tue Mar 23 2010 11:17pm |
You forgot
Tue Mar 23 2010 11:20pm |
Shouldn't that be
Tue Mar 23 2010 11:39pm |
BulletProofBomb Member Since: 12 Jan 2010 Location: Lanarkshire Posts: 164 |
Took mine into Kwik-Fit recently to have a slow puncture looked at and he asked me to lock it into access height???? Should I smack him in the head next time, and tell him not to be so stupid? I just assumed they knew what they were doing. Iknow, Iknow, Kwik-Fit knowing what there doing is an oxymoron.
Wed Mar 24 2010 12:20am |
NightFox Member Since: 02 Mar 2010 Location: North Shropshire Posts: 381 |
Surely the jack only has the same maximum lift height irrespective of how the car gets to offroad height? Alfa Romeo Giulietta 1.8::MG Montego Turbo::MGB GT::Rover Sterling::MGF::MG ZT 190+ Discovery Series II Td5 GS::Discovery 3 TDV6 S::Freelander 2 TD4 XS::Freelander 2 TD4 SE Range Rover Sport TDV6 3.0 |
Wed Mar 24 2010 7:44am |
Correct but I think Josh means you'd know that without having to lift the vehicle full travel to find out - issue with some trolley jacks, obv the LR jack travels far enough but it is certainly easier to get to height without the load on... |
Wed Mar 24 2010 8:49am |
Ahh, makes sense. Alfa Romeo Giulietta 1.8::MG Montego Turbo::MGB GT::Rover Sterling::MGF::MG ZT 190+
Wed Mar 24 2010 8:50am |
Actually, thinking about it, what Kwikfit said would seem to make more sense; with the car locked at access height surely you wouldn't have to jack the chassis as high before the wheels were clear of the ground (assuming they don't just "dangle"). You might have a jack that wouldn't be able to lift the car when the suspension was fully extended, but it should be able to if in access mode.
Wed Mar 24 2010 8:56am |
No - i think locking is only an electronic and temporary overide - they would mechanically fall under gravity IIRC |
Wed Mar 24 2010 8:58am |
