Home > Technical > TDV8 HSE - Drivers seat movement |
KiwiRRS Member Since: 22 Aug 2007 Location: Wellington Posts: 92 |
My second seat base also started moving. The dealer moved one of the runners slightly ahead of the other to correct the moving problem. However, when moving the seat the motor seems to struggle and the seat moves much slower than the passenger seat. I hope that the motor does not burn out as it is seems to be under load more than before. I wonder howe long it will take LR to release a corrected version and if it would be retrofitted if you are out of warranty? |
Tue Feb 02 2010 1:25am |
Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355 |
Be prepared for long wait - dealers have just replaced mine - and it took 3 weeks while I was in loaner car to get parts released - they are now on restricted parts access. Being an annorake - I think from memory the drivers rail assembly is part number 61710 - maybe wrong - 05-09 drivers seat centre frame section. These are only on VOR orders now with correct paper work submitted. Takes the rock out though. You don't stop playing because you get old, You get old because you stop playing.
Sun Feb 28 2010 7:43pm |
stevedacosta Member Since: 28 Jan 2010 Location: Essex Posts: 4 |
Took the car to the dealership to fix the suspenstion again and they said there is now a fix for the seat? Whilst it is okay at the moment, I am sure it will start moving soon - watch this space!! HST Owner with suspension problems! |
Thu Mar 11 2010 7:19pm |
tomw Member Since: 10 Feb 2009 Location: Lincolnshire Posts: 19 |
Since my last post in this thread the car has had another new seatbase, rails and seat.
Wed Mar 17 2010 11:05am |
I note Tom that you also have suspension problems! join the club and I would suggest you read the information on this website. Basically it cannot be fixed and even the new cars being delivered into the show rooms today have the problem. HST Owner with suspension problems! |
Mon Mar 22 2010 8:14pm |
