Home > Technical > RRS Headlight Component??? |
Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275 |
Looking at the handbook the zenon bulb just seems to be held into the headlamp by a bent wire spring clip hinged on the headlamp. If it is a halogen bulb it is held in by an unattached pressed steel spring plate that isn't available from LR if you lose it - as someone downunder found out. |
Fri Mar 12 2010 9:15pm |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 |
Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
Sat Mar 13 2010 8:41am |
Did you manage to get one in the end Zilch? |
Sat Mar 13 2010 9:47am |
Bob no, but at this moment one gentleman from D3 site (TLO), i believe he is a parts managers from LR in Yeovil is looking through some of the breakers for me.. also one parts manager in OZ is also looking through any warranty returns.. Its a joke that you cannot get some thing simple as a Bulb retaining clip without the need to spend hundreds of dollars on a replacement unit..
Sat Mar 13 2010 9:57am |
Glad to hear you managed a temporary fix.
Sun Mar 14 2010 9:01am |
