Home > Technical > RRS Headlight Component???
kerryman
Ireland 2006 Range Rover Sport TDV6 HSE Zambezi Silver
Can anyone identify the component that the xenon bulb fits into in the headlight of a 2006 RRS?
I think it may be the same component found on the Ford Focus & Mondeo but not sure.
Post #259334 Fri Mar 12 2010 8:35pm
Bob.
Looking at the handbook the zenon bulb just seems to be held into the headlamp by a bent wire spring clip hinged on the headlamp. If it is a halogen bulb it is held in by an unattached pressed steel spring plate that isn't available from LR if you lose it - as someone downunder found out.
Post #259358 Fri Mar 12 2010 9:15pm
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Whistle Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #259394 Sat Mar 13 2010 8:41am
Bob.
Did you manage to get one in the end Zilch?
Post #259398 Sat Mar 13 2010 9:47am
Zilch
Bob no, but at this moment one gentleman from D3 site (TLO), i believe he is a parts managers from LR in Yeovil is looking through some of the breakers for me.. also one parts manager in OZ is also looking through any warranty returns.. Its a joke that you cannot get some thing simple as a Bulb retaining clip without the need to spend hundreds of dollars on a replacement unit..
At the moment i am using an "elastic band" Laughing Bow down to the rubber band its saving me a fortune Rolling with laughter
Jim Another Pommie Bar Steward down under
Post #259400 Sat Mar 13 2010 9:57am
Bob.
Glad to hear you managed a temporary fix. Thumbs Up
It makes you wonder how many D3s and RRSs with halogen lights are running around with rubber band or other fixes without the owners knowing. After all if a dealer's technician drops that clip are they going to ask the boss if they can replace the whole headlamp and only charge the customer for a bulb? Rolling with laughter
Post #259501 Sun Mar 14 2010 9:01am
