![]() | Home > Maintenance & Modifications > Brake Disc Change? |
reidnul Member Since: 21 Jul 2008 Location: austria Posts: 36 ![]() ![]() |
I have just taken it in as the Brake warning light came on indicating what i thought was a brake pad change. They do need changing (although it looked to me when i just visited the dealer that there was a good 5mm still left) but the dealer has said that they want to change the front discs too. They look fine and I dont have the mm thickness yet from the dealer, but does any know how often discs need changing?
All depends on driving style. I went through 2 complete sets in 26k (miles) when I had mine...others have reported better time between swaps. Fronts usually wear quicker than the rears, so dealer might not be far off but it's not unknown for service depts to want to change everything on your car of course |
discs....?....! |
I have had the car from 3000 miles and as far as i can recall yes, this is the first pad change. Its not the pads that I am questioning however. New discs at 38000miles????? |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
Previous owner of my last TDV8 had new discs and pads all round at 32k miles. FF 4.4 V8 Soooo looking forward to this bad boy
just spoke to a few Range Rover dealers and the general opinion is that discs can go at this mileage so it is possible although seems odd that i am going to have to change discs every time with pads. they also said to always change the brake warning sensors at the same time.
Jonathan Member Since: 11 Jan 2008 Location: York Posts: 434 ![]() ![]() ![]() |
My dics needed changing at 40k so you are in the right ball park. |
dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851 ![]() ![]() |
No mate I realise that you are talking about the discs, just can't belieeve the pads have lasted so long! i expect I will be getting round to another set of pads AND discs by the time my cars has similar miles to yours. ![]() Daz 2017 4.4 Autobiography FFRR - love this car Gone - VW T5 Transporter Long gone - 2009 Disco Long gone but never out of my thoughts - 2008 TDV8 HST |
turns out that i HAVE had the pads changed once before at 24000miles, duuuurrrrr!
McBunny Member Since: 18 Sep 2008 Location: South Posts: 679 ![]() ![]() ![]() |
Mine will need a change soon (pads and discs), I have now about 100,000 kms (60,000 mls), pads lasted about 40,000, discs are original. |
Rob_J Member Since: 02 Nov 2005 Location: Usually flat out on the sofa with glass of vino Posts: 218 ![]() ![]() ![]() |
To be honest there is no way discs & pads should need changing together. I'd normally not expect to change discs anymore than at every other pad change. HSE TD6 (Java Black/Ivory) 911GT3 (Guards Red, carbon interior) ElanSE (BRG) Panamera Turbo S Boxster S |
Tandem Member Since: 25 Sep 2009 Location: South Wales Posts: 28 ![]() ![]() ![]() |
Discs wear out more these days because the pads contain no asbestos. The compounds used in the pads are more abrasive and as a result the disc takes more of a hammerring.
JonnyDangerous Member Since: 09 Nov 2009 Location: Reading Posts: 57 ![]() ![]() ![]() |
yikes - the wife has had an X5 now since Sept 2004. Done 70,000 miles on the same disks and only had one set of pads. i prefer my MY10 but it seems the X5 is much cheaper to maintain - especially given the ~18 month service intervals. |
