![]() | Home > General > Gremlins in the dashboard |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
There has been quite a few posts on this; it seems to be a common issue. Try the search facility and hopefully this will point you in the right direction. |
flybouy Member Since: 04 Feb 2010 Location: Here, there or in the air.... Posts: 44 ![]() ![]() ![]() |
Thanks I did do a search but nothing came up. Will try again.
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
i'd love to know the answer, if you find it! |
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816 ![]() ![]() ![]() |
Mines the same |
samd Member Since: 21 Sep 2009 Location: Derbyshire Posts: 125 ![]() ![]() |
Same here - I just put it down to a cracking good car |
I did a lot of searching and finally found a couple of threads that have covered the same problem. It seems Bradders is right....it is a common problem. You almost think the designers did not apply a lot of brain in designing the interior or choosing the materials they were going to use |
furtive Member Since: 06 Jan 2010 Location: London Posts: 5 ![]() ![]() |
My 5-series BMW does this in really cold weather. Something in the dash cracks as it warms up, and it's common according to the 5-series forums |
I used to own a 3 series before going for RR sport and that never creaked.....maybe the more money you spend the more sound effects you get for free. ![]() |
