Home > Technical > Emergency Park Brake Release?
rrs2010
I was sat pondering today and suddenly thought about the emergency park brake release cable fitted on my D3...
Does my RRS have one and if so where is it located? I had a quick look for loose covers but didn't find anything Confused Cheers Paul
2006 TDV6 HSE - Cairns Blue
Tow Pack, Privacy Glass, PTI, DVD.
Post #258150 Thu Mar 04 2010 9:31pm
MAW
IIRC it is under the cupholders somewhere - nightmare to get to in an 'emergency' Confused
Post #258152 Thu Mar 04 2010 9:47pm
Bob.
I think someone posted a "how to" not too long ago, but for RHD here's a picture showing the tools from the car tool kit attached to the emergency release cable loop below the EPB switch. (This has to be removed together with the trim panel in front of it for access.) The black rod is the part of the jack handle with the loop on the end, the screwdriver acts as a handle which you pull up on.
Post #258158 Thu Mar 04 2010 10:11pm
rrs2010
Nice one Bob.. I'm hoping I never need it but it's nice to know where to look Thumbs Up
I presume you have to unscrew the handbrake switch? Cheers Paul
Post #258159 Thu Mar 04 2010 10:18pm
Bob.
Pity there is no information in the handbook. I took these pictures about a year ago when I wanted to know where the emergency release was and how to operate it, having read stories of the brake jamming on and immobilising the vehicle.
First remove the trim cover in front of the switch by inserting the screwdriver in the slot and pressing in to release the trim.
Then remove the two EPB switch retaining screws. When the switch is moved out of the way, with the help of a torch you will see the wire loop of the emergency relase cable. I gather it takes a very strong pull to release.
Post #258207 Fri Mar 05 2010 10:22am
rrs2010
Top man, Thanks very much Bob Thumbs Up Cheers Paul
Post #258210 Fri Mar 05 2010 10:44am
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
Has anyone got an EPB release process for a right hand drive 2011 model RRS as the area in front of the EPB switch has been redesigned compared with the examples above.?
I have done a search of the website with no luck. Sad
Thanks and regards,
Barryp 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #354110 Sat Aug 18 2012 1:21pm
TheDB
EPB Emergency release
Never knew this.
Moderator - should not this be a sticky
Post #354112 Sat Aug 18 2012 1:25pm
Bob.
In case anyone needs to know, say for vehicle recovery if there is no electrical power, the emergency release to get the gearlever out of Park is accessed down the same hole as the EPB emergency release.
Post #354134 Sat Aug 18 2012 9:36pm
Barryp
Re my post above the change to the consul in front of the park brake switch post 2010 now has a leather gaiter around the gear lever. To access the PBR reset cable I presume that you pull up the surround around the gear lever leather surround assumimg that it is held in with the usual LR clips.
Not game to tug on it in case there is something else holding it in.
Don't need to do it now but like to know in case I get a screacher at some point. Question
Thanks and Regards
Post #354175 Sun Aug 19 2012 9:54pm
Bobby
Barryp wrote:
.. I presume that you pull up the surround around the gear lever leather surround assumimg that it is held in with the usual LR clips.
This...?
 Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #354177 Sun Aug 19 2012 10:57pm
Barryp
Thanks Bobby, wasn't game to try incase something snapped Laughing
Regards
barryp 2017 Range Rover Sport TDV6 L494 SE Fuji White
Post #354182 Mon Aug 20 2012 2:21am
pom2
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
On the 2010 -> model the process to get out of PARK is as follows...
1. Pull the gaiter up around the gear change lever to expose the slot it moves in below.
2. To the right of the gear lever adjacent to the 'N' position is a round hole approx 3mm in diameter
3. In the round hole you will see a white 'button'.
4. Push this white button down gently about 5mm to 10mm with a terminal screwdriver or other small suitable object at the same time trying to pull the gear lever back as normal.
5. You will find the lever comes back without any effort as normal.
If you are working around the car push the lever left into tip mode and that will prevent it from being pushed forward accidentally. If you are going to move the car you'll need to leave it in Neutral.
I had to do this today on a 2010 model RRS 3.0 V6.
I have to replace airbags, airbag ecu, dash, front bumper, wing, headlight and a few other bits so if I don't see instructions here I will post.
Post #382740 Fri May 10 2013 10:35pm
spooky
Switzerland
Used this yesterday on my rrs 2013... 3 garages did not know what to do, this forum saved me Smile
Post #494814 Sun May 01 2016 9:08am
LG8340
England 2013 Range Rover Sport SDV6 HSE Lux Santorini Black
Hi
The MY13 is different to the MY10 so how exactly did you access the emergency release please?
Kr
Michael RRS (MY13) Santorini Black SDV6 HSE luxuary
Gone: Evoque, Freelander 2, Mercedes 320 CLK, Porsche 911's
Post #494835 Sun May 01 2016 2:11pm
