![]() | Home > General > LED Running Lights 2010 RRS |
They have to be turned on via IDS if I'm not mistaken, so whoever does it will need that at least. |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 ![]() ![]() ![]() |
and if I remember correctly, the led running lights on the 2010 rrs is the led + the low beam... Think someone on the forum asked his dealer to activate them and he was not happy that it has to been both and not only the led.... Range Rover Vogue ‘17 TDV6
I wonder if having to have both sets on is because the LR LEDs are not bright enough to be daytime running lights but a more a bit of "styling". When you see how bright the daylight running LEDs are on Mercs, Audis, SAABs, Porsches and Vauxhall Insignia the LR version are quite dim and need the dim dip lights to boost them. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Think you are absolutly right Tim Range Rover Vogue ‘17 TDV6 Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 |
viper Member Since: 21 Apr 2007 Location: chester le street Posts: 857 ![]() ![]() ![]() |
spot on tim i asked to have them activated and they couldnt as the lights are not classed as day time running lights as they are not bright enough typical |
Do what I do these days, drive all the time on dipped headlights. It's amazing how much further away you see an oncoming car running on the LED lights that I have decided to drive all the time with my lights on.
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
Totally agree Tim, I never use the Auto On feature as I simply don't trust it after several times where the lights have not come on early enough for the conditions. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black 2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby) GONE - RRS - 3.0 TDV6 HSE - Santorini (2010) GONE - RRS - 2.7 TDV6 HSE - Java Black (2007) GONE - Porsche Boxster S - 3.2 - Black ![]() |
Let them delete it for 2011MY but they can replace it with photochromic wing mirrors that dip to green like the rear view mirror! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Isn't it from next year that all new cars in the UK have to have DRLs anyway? |
gordon kerr Member Since: 14 Jan 2010 Location: Bedford Posts: 49 ![]() ![]() ![]() |
A matter of personal opinion surely? If anything, I usually find that the auto lights come on before I would switch them on and stay on later than I would leave them on. Pesronally I hate day running lights on cars as I feel that they make the roads far LESS SAFE for bikers. I believe the resaon we see bikers with their lights on is because it is unusual to see a vehicle with its lights on in the daytime and once all vehciles have to have lights on all the time they will lose this small advantage. As for the Land Rover auto system I leave it on all the time and generally find it satisfactory. The one time I had a real issue with it was on a foggy day when it seemed totally unable to decide whether it should turn the lights on or not, turning them on and off repeatedly as I drove along, problem simply solved by a small turn of the switch to put them on permanently. Gordon Kerr Bedford, UK 2007 Java Black RR Sport TDv6 1980 Brooklands Green Triumph TR7 |
RAD Member Since: 23 Sep 2005 Location: In the chippy! Posts: 309 ![]() ![]() ![]() |
Have a look at:-
