Home > General > MY10 Satnav - store current position
JonnyDangerous
Probably a dumb question(s) but I can't work out two things.
1. Is it possible to store your current position as a stored destination? If so, how?
2. When i've entered a destination i can see how many miles and minutes until i reach my destination. Is there a way to see estimated arrival time rather than having to work it out?
Post #257890 Tue Mar 02 2010 10:39pm
MAW
I am sure yes to both, need to be in front to check where how etc. On 1 pretty sure - on 2 definately - bottom LHS of screen but maybe i selected a setting - if no one beats me to it i'll go have a look and report ....
Post #257891 Tue Mar 02 2010 10:43pm
MAW
Oh - IIRC the ETA timing is pretty poor - something to do with how average speed is calculated IIRC Confused
Post #257892 Tue Mar 02 2010 10:45pm
RichardM
2010 Range Rover Sport TDV8 HSE Galway Green
Its not bad. I have mine set to show ETA and it does seem to use your average speed rather than some arbitrary speed for the road. If you drive at 90mph on the motorway it will show an accurate ETA, then settle down to 60mph and it adjusts it. On my trip up north recently it added half an hour to the ETA after a while sitting at 60mph (traffic!). WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
2010 TDV8 HSE Galway Green - Adaptive Cruise - Sunroof - Privacy Glass - 5 Spoke Alloys
2009 TDV6 3.0 HSE Buckingham Blue - GONE
Post #257898 Tue Mar 02 2010 11:21pm
NightFox
Re: MY10 Satnav - store current position
If it's the same as the Freelander one, if you touch the "button" that tells you how many miles/minutes remaining, it will give you a menu where you can select to show ETA instead. Alfa Romeo Giulietta 1.8::MG Montego Turbo::MGB GT::Rover Sterling::MGF::MG ZT 190+
Discovery Series II Td5 GS::Discovery 3 TDV6 S::Freelander 2 TD4 XS::Freelander 2 TD4 SE
Zermatt Silver Range Rover Sport TDV6 3.0
Post #257905 Wed Mar 03 2010 12:45am
Tim in Scotland
IIRC To store the current position - press the touchscreen at the cursor, it will ask if you want to make this the destination and remember it in the list of recent destinations. To go back to it later you have to use the list of "recent" destinations to get it back out in the future. I cannot remember how to edit the address. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #257917 Wed Mar 03 2010 7:38am
949BFN
South Africa 2007 Range Rover Sport Supercharged Chawton White
Unlike handheld units like those from Garmin (which use the pre-programmed speed limit of the roads), the RRS unit without a doubt takes the actual current speed of the vehicle into account and adjusts the ETA accordingly. I prefer the RRS way of doing.
What I don’t accept, is that the system is disabled once on the move (at least in USA and now here in SA as well), while more complicated entries can be made in the telephone system e.g. Makes absolutely no sense whatsoever and is just simply annoying. 2010 Sport Supercharged with all options apart from TV and Extended leather (wish I had the latter) (Previously 2007 RRS S/C)
Post #258021 Wed Mar 03 2010 5:35pm
RichardM
No such problem on UK models sorry, all the menu's are available on the move. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
Post #258048 Wed Mar 03 2010 9:27pm
Landlord
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
Touch the screen where it shows the time to destination and it will change to ETA.
If you touch the compass it will change from north up to head up display. MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
MY07 TDV6 HSE, Zermatt Silver, Gone
1964 Austin Healey 3000
2007 LR Defender
2011 VW Tiguan R Line
Post #258076 Thu Mar 04 2010 9:13am
Tim in Scotland
Landlord, I prefer Head up to North up for the car satnav, but at work I am used to North-up for radars and electronic charts................................ 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #258079 Thu Mar 04 2010 9:41am
Landlord
Tim yes likewise,
Was just enlightning Dangerous Jonny on the touch screen facility.
Amazing how many Yacht Crew still come through from training centres with a preference for HUD / CUD. Foreign crews seem to be the worst ! MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
2007 LR Defender
Post #258100 Thu Mar 04 2010 11:35am
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
if the ETA calculation is like the MY07 then it is Censored
that's all, really!
Post #258345 Fri Mar 05 2010 11:52pm
