![]() | Home > General > MY10, Blackberry, Bluetooth and international phone codes |
RichardM Member Since: 24 Sep 2009 Location: Herts Posts: 745 ![]() ![]() |
I just thought it didn't display the name! All mine are in +44 format too. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
JonnyDangerous Member Since: 09 Nov 2009 Location: Reading Posts: 57 ![]() ![]() ![]() |
I'm not sure what you mean Richard?? Does it work fine on yours? Do you see the name or just the number? |
Just the number like you. I had assumed this is all it ever did. I didn't realise removing the +44 would make it display the name. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
I *think* there may be a way around this but i need to take a trip overseas to test it. Blackberry have an option called 'smart dialling'. You basically tell it which country you call the most often (and the country code) and, i think, it automatically adds the country code to any number you ring that doesn't already have an international dialling code, meaning that when overseas my address book should still work with normal UK numbers. If it works the way i think it works i should be able to take all the +44 prefixes off my UK numbers and everything should be hunky dory when i'm travelling. Still - it would be much better if Land Rover's phone system just knew how to interpret a number with an international prefix. |
acucobol Member Since: 23 Jun 2007 Location: Bristol Posts: 21 ![]() ![]() ![]() |
Have you tried 0044 instead of +44 |
That won't work in all countries though, in America you have to dial 01144 on your mobile to get the UK. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award 2010 TDV8 HSE Galway Green - Adaptive Cruise - Sunroof - Privacy Glass - 5 Spoke Alloys 2009 TDV6 3.0 HSE Buckingham Blue - GONE |
