Home > Maintenance & Modifications > Parking sensors screaming!!!
Tim in Scotland
Road muck at this time of year can also upset them, check all the sensors are clean, they don't like to have lots of road salt on them 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #257041 Tue Feb 23 2010 9:50pm
4wheeldriver
Scotland 2010 Range Rover Sport TDV8 Autobiography Stornoway Grey
Ive had exactly the same problem with mine. I wiped them, washed them the lot to make sure they werent frozen etc and they still kept beeping. Dealer couldnt find a fault with them even though it did it in the forecourt and I went and got them out while it was doing it. Now its stopped and hasnt done it for weeks. 1 of those LR "features" I doubt..... Big Cry Big Cry Current, M135i in Estoril Blue with more extras than the cast of Ben Hur.
535d m-sport Platinum grey and a few extras.... Gone
X5 3.0 sd in Space Grey, 20's, Dynamic Pack, Memory Pack, Media Pack, Tow Pack, Rear DVD, Panoramic Sunroof, Steps, 7 Seat Pack, Reversing Camera with moving lines, programmable park heat, etc etc etc - Gone
Range Rover Sport Santorini, privacy, dvd, towpack GONE!!!
Post #257122 Wed Feb 24 2010 4:35pm
rrs2010
Mines in the local main dealer at the moment, Back bumper is off Shocked awaiting new sensor.. Should get it back tomorrow morning Smile Cheers Paul
2006 TDV6 HSE - Cairns Blue
Tow Pack, Privacy Glass, PTI, DVD.
Post #257134 Wed Feb 24 2010 7:07pm
rrs2010
Just got it back form the dealers, new sensor fitted and working correctly again..
All covered under warranty Very Happy Cheers Paul
Post #257240 Thu Feb 25 2010 4:19pm
RRSSTEVE
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
to test pdc sensors switch ignition on, engine off,select reverse gear if you then put your ear to sensors in turn you should hear a faint but audible clicking. if the light inside flashes there is a fault with the system either a sensor or wiring damage.
Post #257570 Sun Feb 28 2010 3:09pm
shuzzy
Had nothing but grief with my parking sensors. First time it went in it needed a new sensor, a month later it needed a new wiring harness front and rear as it has chaffed some and shorted. Total spent so far £260! I hope thats the last of it.
Post #257761 Mon Mar 01 2010 11:59pm
rrs2010
Ouch! Lets hope yours is now trouble free Cheers Paul
Post #257831 Tue Mar 02 2010 4:40pm
stiben
United Kingdom 2006 Range Rover Sport TDV6 HSE Stornoway Grey
Hi all. I'm having a complete mare with mine too. They are totally clean and I'm sure one of the sensors are faulty. Does anyone know if I can buy a single sensor and fit it myself? I think i may know which ones gone because it's got a slight indentation on it. Would that cause the front not work either?
Thanks
ben
Post #258559 Mon Mar 08 2010 10:18am
Bob.
"If a parking aid system fault has occurred, the parking aid module will relay the occurrence of the fault to the driver in the following ways:
 The (switch) status LED will flash at a frequency of 2Hz if the system is active and fault is detected in the sensors, sounders, related wiring or the module.
 The front sounder will emit an error tone for 3 seconds at a frequency of 1500Hz if a fault is detected with the front sensors or the rear sounder develops a fault.
 The rear sounder will emit an error tone for 3 seconds at a frequency of 1500Hz if a fault is detected with the rear sensors, the switch, the LED in the switch or if there is a CAN bus error."
Front and rear sensors are the same - pt no is YDB500301PMA - about £37each
I gather they all clip into housings which are clipped into the back of the bumpers. To change the rear outers you lower the exhaust sufficiently to get the rear boxes out of the way, for the inners it's a bumper off job. Fronts it's a bumper off job to to change any of them.
Post #258697 Mon Mar 08 2010 8:58pm
stiben
well had a look this evening and found that the rear sensor which had a small dent in it is the faulty one (it doesnt click when in reverse) only bad thing is that its second from the end so it looks like im going to have to take the rear bumper off.
ill update once i fit a new one.
Post #258702 Mon Mar 08 2010 9:31pm
svan112
Latvia 2005 Range Rover Sport 4.4 V8 HSE Buckingham Blue
Mine seem to play a trick every now and then but it seems to be weather related some how. The more moist/wet outside and cold the more inaccurate they seem.
If the LED on the board is lit with a steady light, what does that mean?
Post #258913 Wed Mar 10 2010 8:02pm
