![]() | Home > Maintenance & Modifications > Parking sensors screaming!!! |
tornado34 Member Since: 06 Dec 2009 Location: London Posts: 242 ![]() ![]() |
Is it just when you slow down or stop? |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
Check they are not covered in snow, ice or just plain old dirt. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black 2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby) GONE - RRS - 3.0 TDV6 HSE - Santorini (2010) GONE - RRS - 2.7 TDV6 HSE - Java Black (2007) GONE - Porsche Boxster S - 3.2 - Black ![]() |
as Endjin says, it's likely to be one of the three - just remember, DON'T pressure wash them - they get destroyed.
weeble Member Since: 23 Sep 2007 Location: hinckley Posts: 25 ![]() ![]() ![]() |
i have washed them several times and the damn things keep doing it. |
Maybe there's some ice inside the sensor? Try warming them gently with a hairdryer to see if that solves the problem. Maybe you wash them, but if the ice is deeper inside (in that recess) then it will still keep sounding.
If they are still screaming then you do know that you can silence them don't you? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Turning them off |
No need to switch them off, although I would be very tempted to if they were screaming all the time, but for off road use you can silence them and get a red light on the switch when you get too close to objects 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
rrs2010 Member Since: 10 Feb 2010 Location: Leicestershire. Posts: 173 ![]() ![]() ![]() |
I've just reversed off the drive and they started screaming at me |
NJF Member Since: 05 Dec 2009 Location: Normally on DISCO3.CO.UK Posts: 95 ![]() ![]() ![]() |
I get this on my D3 in very cold weather (well below zero C). It stops when the outside temperature rises. Every silver lining has a cloud
Motorbikes use to upset them on the early RRS |
Mines going in the stealers tomorrow... I'll let you know the outcome |
Mine started for the first time yesterday, but it was minus 28 and I had just washed it 10 mins before (indoors and leathered it) - so therefore I conclude it is linked to icing up.
I had mine parked in a heated garage at work today and it didn't solve my problem..
