Home > For Sale & Wanted > Clearance on Castrol car oils
oilman
Site Supporter
Folks,
We've added a Clearance section to our web site where you can buy oils we're over-stocked on or are clearing down.
In the clearance section at the moment, we've a selection of Castrol oils including Castrol Edge and Edge Sport in 1 litres, Castrol Magnatec, Castrol GTX and some Castrol gear oils.
They're all at substantially reduced prices and your 10% club discount applies too.
Take a look at our clearance section here: http://www.opieoils.co.uk/c-1089-clearance-car-oils.aspx
oilman
Post #255142 Fri Feb 12 2010 1:52pm
oilman - can you remind the forum what oils are suitable for the TDV6, TDV8 and SC.
Thanks 2005 Zambezi TDV6 - Gone but not forgotten
Post #255143 Fri Feb 12 2010 1:55pm
oilman
Site Supporter
Okay, here you go
TDV6, needs a Ford 934B oil (5w-30, low SAPS). We don't actually have one at the moment, it's on it's way, but we do have a 934A oil that people have purchased for the TDV6 as 934B is just an updated 934A
http://www.opieoils.co.uk/p-874-motul-8100...gines.aspx
TDV8, needs a Ford 913B spec oil and we have plenty of those
http://www.opieoils.co.uk/c-698-wss-m2c-913-b.aspx
The SC needs a 5w-20 oil and we only have one suitable (5w-20 is a rare oil in the UK), but it is a top quality oil
http://www.opieoils.co.uk/p-1000-redline-h...5w-20.aspx
I believe the SC is a US engine, and many of them are now using 5w-20 oils. Sometimes a 5w-30 will be okay, but a lot of the time people complain that unless they use a 5w-20, the engines feel a bit unresponsive.
Tim
Post #255199 Fri Feb 12 2010 4:42pm
ViewWise
The uk manual states:
Diesel Vehicles - Use SAE 5w-30 meeting specification WSS-M2C913-B only.
Petrol Vehicles - WSS-M2C913-B*
*If you are unable to find an oil that meets the specification defined by WSS-M2C913-B, you must use an SAE 5-30 oil meeting specification ACEA:A3/B3.
Land rover recommends Castrol.
Oil man what in your opinion would happen if you were to put say shell 10w40 (which afaik only meets the ACEA:A3/B3 standard) into a diesel vehicle requiring the 5w-30 ford 913-b? WINNER - 2008 Best All New Photograph
WINNER - 2009 Best All New Photograph
Post #255334 Sat Feb 13 2010 12:54pm
oilman
Site Supporter
I doubt anything will happen. 5w-30 is used as a fuel economy grade.
Guy
Post #255369 Sat Feb 13 2010 6:56pm
