Home > Technical > CHIP TUNING THE TDV 6
annsjovis
Belgium 2010 Range Rover Sport 3.0 TDV6 SE Bourneville
Hi everybody,
I have ordere my RRS TDV 6 SE 2 weeks ago, which i will receive here in Belgium in May.
Ordered the car with the 210bhp setting as there is €2500 put into traffic-taxes to be paid instead of the €5000 on the full 245 bhp version.
Now i was thinking to chip-tune this engine after i drove it for about 3000 kms.
Has anyone some advice or experience in this matter, and is it safe to tune it above the 245 bhp which is the standard from the constructor??
Thanks for your replies Surprised
G from B
Post #254442 Mon Feb 08 2010 8:15pm
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
Welkom, was just going through this exact same conversation with the step-son, he wants a D4 commercial (not available in BE) but wants it with the 3.0TDV6 and dosn't want to pay the €5000 tax either so we were looking at chipping options too. Not made any descisions yet and still waiting to get prices/build times.
Al van Limburg Mr. Green
PS love the waffles in the Silversands cafe on the beach front Thumbs Up Sons of dogs come hither and get flesh
Clan Cameron
Post #254458 Mon Feb 08 2010 9:32pm
joep
Superb waffles indeed!
Post #255550 Sun Feb 14 2010 8:52pm
rickyrr
Belgium 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi Guys,
Tuning is already available but be carefull. For example ziptuning.be although i don't have experience with them.
They do have a rolling road dyno though. It is better to wait a little longer and see other tuners come with their versions so you can compare prices and performance offered.
The maximum torque of the gearbox should be around 700nm.
see http://www.apra-europe.org/dateien/gallery...oducts.pdf
I dont know about the enginelife when reaching 100k km when tuned but with normal use the engine should be fine even when tuned. If you do find a tuner who will map the car on a Rolling Road Dyno then keep the Torque simular or slighlty above the 245 Hp 600 Nm version then you will be fine.
regards,
Ricky RRS 2010 3.0 TDV6 HSE Santorini Black
Post #257052 Tue Feb 23 2010 11:11pm
avos
Before choosing, you should also take in to consideration, that with this relatively new engine, it is likely that you get software updates for this. Evolve and BAS remap, both offer a device with their tuning package (at least for the 2.7 version) that can bring back the ECU tune to standard before you go to a dealer, and if they have reflashed your ECU, Both Evolve and BAS can give you a new tune based on the new ECU software (FOC I thought, better ask them ). I do not see that Ziptuning offers the same, better to ask them also.
The torque rating is indeed 700nm of the new 6HP28x box, but that is for continues use, occasionally 10% above should not destruct your box. Have had a RRS SC with over 700 nm on the older ZF 6HP26x box that was only rated to 600nm, and the power was used almost continues and it proved to hold Wink. RRS SDV6 HEV Dynamic
XKR 700 BHP with Twin-screw and LSD
Post #257063 Wed Feb 24 2010 7:46am
bellautos
United Kingdom 2005 Range Rover Sport TDV6 HSE Cairns Blue
Hi
Yes a dyno is good and we always use one for final set up, but temperatures etc etc also need monitoring for long periods of time to be sure of a safe tune, which is not pratical on a dyno.
The only way to do this reliably is to have a car for a long time monitering it every day in use, or even better own a car with the same new 3.0l engine in it.
Hence why i paid over 40k for a D4 as a developement tool and have had tuning for nearly 2000 miles and still testing monitoring and adjusting before any public release.
@avos, Sadly the current BAS interface wont work on this new model due to the Anti-Tuning protection implemented by Bosch on the new ecu.
Pete
Post #257069 Wed Feb 24 2010 9:42am
avos
Just found out that Rica in the Netherlands is also offering a map for the new 3.0 engine:
http://www.rica.nl/viewcar.aspx?vehicle=1928
Tuned:
RICA 299 hp @ 3900 rpm 710 Nm @ 2100 rpm RRS SDV6 HEV Dynamic
Post #258365 Sat Mar 06 2010 8:32am
vogue se
Belgium 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Is it possible to just switch the ECU from a 245 hp?
Post #262295 Wed Apr 07 2010 7:22pm
quantz
Re: CHIP TUNING THE TDV 6
annsjovis wrote:
Hi everybody,
You mean 155 KWh. 2010 TDV6 3.0 HSE Santorini Black Tan Full Leather
Post #262296 Wed Apr 07 2010 7:29pm
