Home > Australia & New Zealand > Interesting scenario with flat tyre and warning lights
Jimmy Salsa
Australia
Coming home from work tonight I had a puncture and enjoyed? a few white knuckle moments as the car starting sliding sideways going through a roundabout and the tyre collapsed under the roll of the car.
I was only a block from a servo so I gently wrangled the car to a flat area at the back of the servo where I could at least have some light.
After fiddling around with the very badly designed standard jack (note to self to purchase bushranger exhaust jack tomorrow) to raise the car, I finally got the spare on but...
I'm running 285/60's all round except for the spare as the bigger rubber doesn't fit in the spare wheel well. The spare is standard street rubber. The size difference is significant but I didn't have a lot of choice and decided to nurse the car the 30kms to home.
As soon as I started driving off the dash lit up like vegas, with warning lights galore.
From what I can work out, the car detected the change in height at the rear and immediately Censored off the ABS and DSC as well as showed a fault with the HDC(strange). It then lowered the suspension (I assume for stability) to compensate for the error and showed a strange icon (bottom left) of a car with arrows indicating the uneven balance/roll of the car.
I assume the car will automatically detect the return to normal ride height tomorrow when the tyre is repaired and fitted but was interested to see if anyone else had come across similar situations, or knew about the protocols programmed into the car for situations like this? 'Black Betty' Java Black RRS 07 TDV6
Post #253856 Fri Feb 05 2010 10:48am
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Rolling with laughter Rolling with laughter servo Rolling with laughter Rolling with laughter
Ah, god love em Wink (Aussies) Thumbs Up L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #253863 Fri Feb 05 2010 11:08am
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
HST SC'S lower themselves gently, a butler gets out the back and changes the tyre, if this does not fix it, the owner can hitch a ride on the butlers back to the nearest Limo hire, whilst the offending vehicle is wafted to the nearest "point of fixing" Whistle Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #253869 Fri Feb 05 2010 11:32am
Jimmy Salsa
Australia
The tyre was a blow out and there is a 6inch split in the middle of the tread so will be interesting to see if Coopers honour their 50,000km warranty.
Had the original street rubber fitted all round and as soon as the car realised everything was back in balance, all the warning lights have disappeared.
Very clever stuff. 'Black Betty' Java Black RRS 07 TDV6
Post #254042 Sat Feb 06 2010 11:20am
SpikeUK
Re: Interesting scenario with flat tyre and warning lights
Jimmy Salsa wrote:
... and immediately Censored off the ABS and DSC ...
Mmmm, that sounds about right.
Rolling with laughter Rolling with laughter Rolling with laughter
Post #254047 Sat Feb 06 2010 12:21pm
SpikeUK
I Looked up the bushranger exhaust jack - it's an interesting gadget, but I did notice on their site:
Never use X Jack for vehicle maintenance, accessory fitment or wheel removal.
Nor recommended for wheel removal, then.
Post #254050 Sat Feb 06 2010 12:37pm
Tim in Scotland
In the early days of RRS there were several instances of the supplied cheap jack collapsing, IIRC on one occassion trapping the owner under the car when he was changing a wheel. SO be very careful using the supplied jack, it sin't up to the job. if you still have LR Assist cover then call out the LRA/AA to change the wheel. It has the added advantage that you also stay clean! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #254057 Sat Feb 06 2010 2:30pm
Leo
Kenya
I think they're just covering themselves legally. I'd trust an air jack over the LR one.
Post #254059 Sat Feb 06 2010 2:34pm
Tim in Scotland
There is a version suitable for heavier SUVs that the Disco3 guys bought a load of with a group buy - Very Annoyed has one IIRC. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #254061 Sat Feb 06 2010 2:39pm
Batts
England 2007 Range Rover Sport TDV8 HSE Stornoway Grey
I have exactly the same problem as Jimmy in this original post. Anyone got any answers please? Thanks
Post #365065 Sat Dec 01 2012 11:44am
disco4x4au
Australia 2013 Range Rover Sport SDV6 SE Santorini Black
Odd - mine does, albeit only when deflated? Is the spare well different on the pre-2010 RRS?
Cheers,
Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers
2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT
Post #365215 Mon Dec 03 2012 1:02am
RichG
Australia 2008 Range Rover Sport TDV6 SE Chawton White
So Jimmy Salsa you're a member on this forum - I've been watching your exploits on youtube, very impressed, it was actually your videos that was the last bit of convincing I needed to buy an RRS. Would love to join you guys whenever you're heading out again - just have to get the right rubber. Heading up Cape York in feb too although will probably stick to the bypass road this time as my RRS is literally immaculate and I want to keep it that way as long as possible!!
I noticed you had sunnies - are they the ones off ebay?? MY08 RRS TDV6, Chawton/Black, sunroof, hk, 268k km
2001 Audi A4 1.8T quattro 5mt sport, 340k km
1990 Nissan Pintara TRX, lots of mods, 438k km
Post #365483 Tue Dec 04 2012 10:01pm
garrycol
Australia
Cape York in Feb???? It is still in the Wet - i doubt you will get very far. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #365497 Wed Dec 05 2012 4:30am
Zilch
concur, lived in tropical queensland for 2 years from 2008 to 2010, even the tarmac becomes impassable in the wet season Laughing not rubber you need, its a boat Whistle Another Pommie Bar Steward down under
Post #365508 Wed Dec 05 2012 10:25am
RichG
I lived on the tableland for six years. I have been up the Cape in Feb before - my mate owns a share in a property up there. Won't be doing the entire trip though since as you said I'd need a boat, but you can make it up past Coen with little fuss. Depends on the year as well. At the start of the ye I drove my Audi up to the tableland and got as far as Laura on a day trip. Loved it, but will have a bit more security in the RRS (almost got flooded on the way back and scraped the undercarriage of the Audi numerous times on the crappy outback roads). MY08 RRS TDV6, Chawton/Black, sunroof, hk, 268k km
Post #365583 Wed Dec 05 2012 11:07pm
