Home > Maintenance & Modifications > Transmission Fluid Change |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 |
Just had the 96KM service and had the transfer box, rear diff oils and transmission fluid changed. i must admit since the Transmission fluid change, the gear change is noticeably smoother, and the low speed acceleration shunt has all but disappeared .. Personally i would ignore the Sealed for Life twaddle and seriously think about changing the fluid at an appropriate time. The service company (LR Specialist not Franchise dealer) suggested that this should be done sooner on those who spend a lot of time off-roading... not many on here then Another Pommie Bar Steward down under
Fri Feb 05 2010 8:18am |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 |
if you don't mind Zilch, What were the $'s to get it all done?? |
Fri Feb 05 2010 8:38am |
$954 Australian all in.. Major service plus everything else, but that was a LR Specialist (accredited by Alliance to undertake extended warranty repairs) not a LR dealership. My usual dealership failed to provide a quotation, although i asked them numerous times over a month, another well known Sydney dealer wanted 2.2K to do the same.
Fri Feb 05 2010 9:44am |
