Home > Technical > First issues with new MY10 |
max099 Member Since: 27 Feb 2006 Location: AT Posts: 16 |
I'll put on the summer tires to give it a try. If this helps then everything is clear... Does anybody know, if the MY10 RRS have damped or non-damped steering gears? see http://www.rrsport.co.uk/forum/viewtopic.php?t=264 (6th post) |
Mon Jan 25 2010 8:59pm |
Summer tires test postponed: it snowed all the night. |
Tue Jan 26 2010 1:57pm |
NJF Member Since: 05 Dec 2009 Location: Normally on DISCO3.CO.UK Posts: 95 |
I had this problem on my last Merc at the same speeds as you and I recall people posting about it on their RRS. It is almost certainly not the tyres. The flat spot theory is implausible, albeit commonly proposed. I had wheels changed, tyres changed, nitrogen inflation, steering rods changed, etc, etc. Merc couldn't fix it. I eventually changed the car and I was glad to get rid of it. I heard from others that it was most likely down to the steering rack - on the Merc and the RRS.
Tue Jan 26 2010 6:36pm |
avos Member Since: 26 Aug 2008 Location: Belgium Posts: 106 |
First of all I am not saying the problem with vibration is flat spotting! But as this is a phenomenon that is real, it is a possibility that should be eliminated to find the true cause (whatever that may be).
Tue Jan 26 2010 7:12pm |
Neta Member Since: 25 Mar 2010 Location: Poland Posts: 1 |
Hi Everybody,
Thu Mar 25 2010 10:57am |
