![]() | Home > Technical > Urgent help needed re: front suspension |
sweetafton Member Since: 05 Dec 2009 Location: Weymouth Posts: 961 ![]() ![]() ![]() |
Car in stealers today. They have removed the dampers in order to stop the front suspension knocking sound. Is this a quick fix or the correct fix? |
See this post: http://www.rrsport.co.uk/forum/topic15691.html |
Thank you thank you. I knew i saw that somewhere but could not find it. Stealer was a bit put out when i said there was other stuff to do. Its yeovil LR. Bit put out with them cause the loner was clean on outside but inside was a mess. My car was immaculate inside and if i was in a suit it would of been ruined. The car (freelander) was a 59 plate with only 2500 on clock so not old. Will kick ass in morn but bet they have not got the damper kit in stock. Cheers again shmoogle your a star. |
Pleasure mate - Nick from Yeovil parts dept is a sponsor over on the D3 forum, he will be in the process of getting the damper kit in hopefully so mention you are from here and he will do his best to look after you |
Here is a question for Bobby (Kuala Lumpar) and Shmoogle (GB).....
Do you have a copy for me to look at? Or can you give me some idea what was in it?
Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Car home now after being with stealer. They would not discuss this new bulletin but have ordered the mass damper kit. They've done the ball joints and removed the dampers. For the boot leak they have ordered a new boot seal. Everything on back order at mo too, so no date when they want it back |
Bobby you are the man. Thank you very much. |
