Home > Technical > Suspension warning light
rabbutler
Scotland 2010 Range Rover Sport TDV8 HSE Alaska White
When I start the car and begin to move off I am getting the orange suspension warning light, indicating Suspension warning excessive travel during cornering.
Anyone had this issue before and idf so what was the fix.
Will be calling th edealer tomorrow so just want to be prepaired with the correct info.
Cheers guys. 2010 Alaska white 3.6TDi v8, heated steering wheel, Ipod connection, Aribica extended leather, Digital TV, voice activation, privacy glass, Dynamic pack
Now gone - Jaguar XKR4.2 v8 Supercharged
Gone - 08 RRS TDI V8 Java Black, Privacy glass 315 BHP tunit box.
Still have - Merc C200 sport
Yahaha FZ1000
Gone - BMW X5 3.0d sport
Post #251563 Sun Jan 24 2010 4:41pm
ASH555
England 2010 Range Rover Sport 3.0 TDV6 HSE Zermatt Silver
I have had the occasional orange warning light, which seems to correct itself with a simple ignition cycle MY10 3.0 TDV6 HSE, Zermatt Silver, 20" Diamond Turned Alloys, Factory Privacy Glass, Premium Leather, Contrast Stiching, Side Steps, Etc
Gone 2006 '56' 2.7 TDV6 HSE, Zermatt Silver, 20", Side Steps, Brembos, Dynamic Pack, Etc
VW Transporter, 19" Rims, T32 170 BHP, Lowered
Post #251567 Sun Jan 24 2010 4:53pm
rabbutler
1st couple of times yes that was the did the trick, but was out today, pushing quite hard on the country B roads, it came on again. When I start it up again and begin to move off it comes on again.
I was also told to switch the ignition on and off 3 time in a row and that should clear any fault codes held in the computer, have yet to try this 2010 Alaska white 3.6TDi v8, heated steering wheel, Ipod connection, Aribica extended leather, Digital TV, voice activation, privacy glass, Dynamic pack
Yahaha FZ1000
Post #251570 Sun Jan 24 2010 5:00pm
Tim in Scotland
Switch your SatNav screen to the offroad mode and look to see if all the sensors are showing as working, I suspect you may have a ride height sensor failure. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #251576 Sun Jan 24 2010 5:10pm
rabbutler
Cheers Tim will give that a try and let you know 2010 Alaska white 3.6TDi v8, heated steering wheel, Ipod connection, Aribica extended leather, Digital TV, voice activation, privacy glass, Dynamic pack
Yahaha FZ1000
Post #251578 Sun Jan 24 2010 5:13pm
MAW
This was my failure last Sunday, orange light then red then the car started to magic carpet, like an old American car... got out and all four corners were way down - looked like lower than access mode.
Restarted car, tried a few selections on height and had a mix of responses, from correct at one time to access on the front and off road at the back Confused
With my fault it said suspension fault and something about max speed 30mph (but was not restricted to that)... got home and the front was at normal IIRC but the rear Shocked higher than off road - MASSIVE gap at the wheel arch....
LRA called out and found a height sensor playing up (NSR) - known fault Rolling Eyes Shocked , water ingress. The Tech showed my the old one, bad connection and a 'green' pin causing the problem. Fitted new one on the drive at home. Thumbs Up
Post #251580 Sun Jan 24 2010 5:21pm
rabbutler
Just been out to try, had the nav screen showing 4x4 info, warning came back but nothing out of the ordinary on the screen, the car still seems to handle OK and corners as usual even though the fault indicates excessive lean while cornering.
MAW, it has been raining rather a lot here in Aberdeen for the last couple of days and did go through some large puddles, but you would yhink that a car such as the RR that has built it's reputation from off road would be ablt to handle puddles on the road. 2010 Alaska white 3.6TDi v8, heated steering wheel, Ipod connection, Aribica extended leather, Digital TV, voice activation, privacy glass, Dynamic pack
Yahaha FZ1000
Post #251583 Sun Jan 24 2010 5:31pm
Tim in Scotland
Whistle Whistle Have you tried calling out LRA to have a look? Whistle Whistle 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #251584 Sun Jan 24 2010 5:35pm
MAW
When mine happened i had just been playing Embarassed in some large puddles .... 20 secs later ..... amber light Laughing
You would think a puddle shouldn't upset such a vehicle wouldn't you - the tech said common fault known about and we had a chat about the fact that 5 years in they should have designed it out Whistle
It'll be the same thng IWE...
I have a pic of the car in dragster mode i'll have to upload sometime Laughing
Oh BTW my 4x4 screen wasn't showing anything either - the tech showed the the sensors output on his laptop - fluctuating around 1.8/1.92v IIRC whilst all others were steady
Post #251586 Sun Jan 24 2010 5:40pm
rabbutler
Not yet becaus it still drives Ok and other than the orange light shining at me there seems to be no difference.
If it goes mad and starts playing up like what happened to MAW then they will be getting a call.
Alslo what is teh deal with LRA?? my car is only 18months old 2010 Alaska white 3.6TDi v8, heated steering wheel, Ipod connection, Aribica extended leather, Digital TV, voice activation, privacy glass, Dynamic pack
Yahaha FZ1000
Post #251588 Sun Jan 24 2010 5:42pm
Tim in Scotland
You have free LRA until the warranty runs out 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #251591 Sun Jan 24 2010 5:44pm
MAW
I'd be tempted to get them out before it plays up, call them now if at home then there is no inconvenience, last thing you want is my magic carpet ride when you need to be somewhere.
Maybe you think the suspensions erratic with its settings as well as the warning light Wink Whistle
Post #251592 Sun Jan 24 2010 5:49pm
rabbutler
If still a problem tomorrow might do just that.
Also do you know where the computer access point in the car is, where the tech would hook up his laptop, I have one of those VI monitors so might just hook it up ands see what it has to say about the error code, 2010 Alaska white 3.6TDi v8, heated steering wheel, Ipod connection, Aribica extended leather, Digital TV, voice activation, privacy glass, Dynamic pack
Yahaha FZ1000
Post #251604 Sun Jan 24 2010 6:53pm
Tim in Scotland
IIRC it is on the underside of the steering column, seem to remember the LRA man having to get into the driver's footwell when I had to call them out for my last RRS continually going into limp-home mode. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #251607 Sun Jan 24 2010 7:02pm
4wheeldriver
Scotland 2010 Range Rover Sport TDV8 Autobiography Stornoway Grey
The OBD port is to the right of the steering column in the footwell. Current, M135i in Estoril Blue with more extras than the cast of Ben Hur.
535d m-sport Platinum grey and a few extras.... Gone
X5 3.0 sd in Space Grey, 20's, Dynamic Pack, Memory Pack, Media Pack, Tow Pack, Rear DVD, Panoramic Sunroof, Steps, 7 Seat Pack, Reversing Camera with moving lines, programmable park heat, etc etc etc - Gone
Range Rover Sport Santorini, privacy, dvd, towpack GONE!!!
Post #251616 Sun Jan 24 2010 7:50pm
