![]() | Home > Technical > Suspension warning light |
rabbutler Member Since: 11 Dec 2009 Location: Aberdeen Posts: 187 ![]() ![]() ![]() |
When I start the car and begin to move off I am getting the orange suspension warning light, indicating Suspension warning excessive travel during cornering.
ASH555 Member Since: 02 Dec 2006 Location: East Yorkshire Posts: 750 ![]() ![]() ![]() |
I have had the occasional orange warning light, which seems to correct itself with a simple ignition cycle MY10 3.0 TDV6 HSE, Zermatt Silver, 20" Diamond Turned Alloys, Factory Privacy Glass, Premium Leather, Contrast Stiching, Side Steps, Etc
1st couple of times yes that was the did the trick, but was out today, pushing quite hard on the country B roads, it came on again. When I start it up again and begin to move off it comes on again.
Cheers Tim will give that a try and let you know 2010 Alaska white 3.6TDi v8, heated steering wheel, Ipod connection, Aribica extended leather, Digital TV, voice activation, privacy glass, Dynamic pack
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
This was my failure last Sunday, orange light then red then the car started to magic carpet, like an old American car... got out and all four corners were way down - looked like lower than access mode.
Just been out to try, had the nav screen showing 4x4 info, warning came back but nothing out of the ordinary on the screen, the car still seems to handle OK and corners as usual even though the fault indicates excessive lean while cornering.
When mine happened i had just been playing |
Not yet becaus it still drives Ok and other than the orange light shining at me there seems to be no difference.
You have free LRA until the warranty runs out 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
I'd be tempted to get them out before it plays up, call them now if at home then there is no inconvenience, last thing you want is my magic carpet ride when you need to be somewhere. Maybe you think the suspensions erratic with its settings as well as the warning light ![]() ![]() |
If still a problem tomorrow might do just that.
IIRC it is on the underside of the steering column, seem to remember the LRA man having to get into the driver's footwell when I had to call them out for my last RRS continually going into limp-home mode. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
4wheeldriver Member Since: 13 May 2009 Location: Aberdeen Posts: 955 ![]() ![]() ![]() |
The OBD port is to the right of the steering column in the footwell. Current, M135i in Estoril Blue with more extras than the cast of Ben Hur.
